Question about the Bronco Lug Nuts
BDR
Ken
West Deptford NJ
2023 Wildtrak Eruption Green, 1991 Miata BRG
OK my Bronco isn't Scheduled to be built until 6/8/2023 however here is my question my wife's 2017 Ford Fusion's stock Lugnuts were a Steel Nut with a Chrome Cover pressed overtop ...... they were terrible and after a Ford Tech may have used an Impact Wrench just a little to hard during a wheel rotation when I went to remove her wheel when she had a flat I needed to Beat a Wrench onto the nut to be able to get enough bite to remove it .... well I fixed that situation with a Proper Lug Wrench and some Gorilla Nuts the wrench supplied to install the Spare was made from Stamped Steel and Rounded out when trying to get the lug nuts off.
So does the Bronco come with a "Real" Lug Wrench or should I plan on getting a Proper Wrench and Socket to leave in the Truck and are the Lug Nuts "Real" or the Cheap Metal with a Dress Cap Pressed overtop.
If so I will be replacing them with a Set of Gorilla Nuts shortly after taking delivery of the Truck.
Thanks
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
That's an excellent question had to replace the OEM "pressed cover" lug nuts with aftermarket solid lugs on Raptor and GT350...
BDR
BDR
Ken
West Deptford NJ
So now I wonder what the Lug Wrench looks like my Wife's Fusion had a Terrible Pressed metal monstrosity that I replaced with a Proper Gorilla Automotive 1721 Telescoping Power Wrench and a Real Socket Sounds like I will be ordering another from Amazon
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Which model Gorilla Nuts fit?
RHeinz
Ric
Houston, TX
Regardless of whose nuts you are using…. Get the proper 6 point socket and a proper breaker bar to get them off and to retighten.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
which gorilla nuts work with the factory wheels?
all the ones i've found explicitly state they're not compatible with factory wheels
TheShark
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
https://www.merricktool.com/ I bought one and carry it with me for others to use. Yes it's very pricy but will NOT round lug nuts off. Nice man that invented it and USA made. Jim.
paperboy
Nelson
Vancouver, BC
2019 Passport
Thanks for this, I was unaware of the Merrick sockets. Is it 19mm that we require? (sorry, I do not have my Bronco yet!)
redone17
Cold Spring, NY
Yes
KABQ
Aaron
Albuquerque, NM
