How do these hold up? My current black lugs I got looks like they are rusting.I think these are the ones you are looking for - this is the 12mm version of the ones I got for my Braptor (which uses 14mm)
https://www.summitracing.com/parts/mcg-64015
Clean off the rust and spray with Griots 3in1 ceramic wax few times a year. Actually use it on everything.How do these hold up? My current black lugs I got looks like they are rusting.
Mine are fine, no issues.How do these hold up? My current black lugs I got looks like they are rusting.
Will DM. Thanks
if anyone needs any black lugs I can get these through my wheel supplier. They are 12x1.50 19mm acorn bulge black duracoat to give longer wear , but all will get marked up and rust in my climate(eastern Canada). I’ve used for 3 winters so far and are still in good shape. Cost is 1.50 per lug (Canadian) plus whatever to ship to you if needed.
I have the McGard's on my other car. After 3 years they still look brand new....How do these hold up? My current black lugs I got looks like they are rusting.
The torque specification for the spare is 66.Can't help with part numbers, but torque is 100 ft. lbs. Exception: spare is only 38. Don't want to crack that plastic mount.
Whoops. Was going from memory.The torque specification for the spare is 66.
