Question about gears/upgrading my tires.
Benallen6
Benjamin
2022 Eruption Green 2 Door Bronco
My base bronco with a 2.7 should be getting here in around a month. I wanted to upgrade the tires from 30 inches to 33. I was just wondering If I need to upgrade the rear axle ratio or anything? I was reading into it a little bit and saw a lot of mixed things so I was just looking for some advice.
mike8675309
Minnesota
All Bronco's have front and rear gears. so if you update the rear, you have to do the front as well.
You shouldn't need to change gears for performance. the V6 or the 4cylinder should have no problem with 33rds and the base gearing.
old goat
Raul
Collin Co. Texas
Chevy Colorado
I ordered my BB with 4.27 for that purpose of tire size
OP did you get the 3.73 gears , changing the gears out after the fact will get pricy
like Mike says you should have no problems with 33's
Benallen6
Benallen6
Benjamin
Mine should be the 3.73 Open Style Rear Axle Final Drive Ratio
mike8675309
Minnesota
The Bronco version of the 2.7 EcoBoost motor has a power curve that has it over 300ftlbs of torque at 1500 rpm and goes up from there.
60mph in 10th gear with 30" tires your rpm is 1604.2
60mph in 10th gear with 33" tires your rpm is 1572.3
