PVO update on the attic tray
Forditude
2017 F-150 5.0 5* Tuned, GX470 Overland
Really like this design. Both the shelf and the board mounts. I would be very interested in a combo set. Thanks for offering these to the community.
Right now I have have Monkey Fist mounts bolted to the nut certs...
da_jokker
Jeep Wrangler JKUR
I'm going to be installing something similar to this as well but using the XG Cargo bags (once they create them for bronco) for the sides and then a panel ran across the top between the two for attic storage.
I guess my point is if you turn those sides into some storage, you may tap into a market that is not developed for the Bronco yet.
Imagine these, with a Molly panel running across the top of them...
XG Cargo Wrangler Gama Adventure JL https://a.co/d/8XjGG8S
Thart89
Tyler
Orlando
Explorer
I'm in for a pre-order bundle If you decide to open pre-orders.
huskerhiker
Ryan
So Cal
2023 4dr Badlands non SAS, modified.
I'm in too on the attic, assuming my Bronco is made one of these days.
UtahBrandon
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
Maybe I missed it but is there a picture with the top on, out of the back window with the tray and the boards mounted underneath. Trying to get an idea how much of the rear window is obstructed. Thanks!
I just realized I didn't post a pic for you. here you go. The attic tray is mounted on top of the Traction Board Brackets but is obscured by the roll bar. The ARB Tred GT boards are mounted underneath the attic tray and Traction Board Bracket
Ford Bronco PVO update on the attic tray IMG_6363
Thart89
Tyler
Orlando
Explorer
Thanks for the picture. That's not nearly as bad as I was expecting or even as bad as I'm used to. I'm definitely in for both whenever they are ready. Thanks again!
MrGreen55
Kyle
Oregon
toyota scion xb
The pre order it up on this for the bronco. In theory looks like you can use both long as the bolt is long enough.
https://xgcargo.com/products/bronco-stealth-gama
vzqhsg
MI
F-150, Badlands
TL;DR is that the attic trays are being cut and bent right now and they should be ready to be picked up this week. I’ll then take them to powder coat which should take another 10 days or so.
In the meantime, I did a quick video to give you more detail on the tray.
Build a hinge on the front facing side of the rack. You can then drop it down to load and unload. Put a lip on the back facing side so stuff doesn't fall out. Can you get them in colors to match your Bronco.? Also would work for....cover your ears...a JEEP.
Nice looking. I only get 3% development fee, or a free rack. :0)
UtahBrandon
UtahBrandon
Brandon
I mean, I like it but have resisted complexity like that as It will add to cost, add potential locations for rust, and will potentially rattle. It works great as is. 😀
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
The traction board bracket won’t fit a two door because the angle of the roll bar is different and it doesn’t have the same available nutserts to mount the bracket.
No idea on load capacity but they’re very durable 12ga steel.
I could probably hold one back from powder if you order early. I’ll dm you when I get it posted on the site.
2dr fitment was going to be my question... If you ever figure a way then I'd be interested.
BlueBoy
Martin
CA
1989 Bronco 351W
Those Attic Trays look ready to ship??
UtahBrandon
UtahBrandon
Brandon
I'm dropping them off at powder coaters today (currently raw 12ga steel). They'll take 7-10 days, then they're ready to ship.
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
Old Class-A trucker here: rear view mirrors are for mallcrawlers! :LOL:
[Edit: the subsequent image you posted clears up that issue. And yes, I do check my rearview mirror...occasionally...:cautious:]
A suggestion for the OP: the side moll support triangles open up possibilities for accessories. As you get your operation up and running, consider a quick-release mount for a fire extinguisher.
The shelf looks ideal for my compressor hoses. Everytime I think my Bronco is "finished," somebody like you comes up with something like this. Good thing my wife doesn't look at the credit card statements very often!
I'll probably put in an order in January. Way to go, Brandon!
