- John
- Sep 3, 2021
- 25
- 2,528
- 2,437
- Pennsylania
- X4
- Outer Banks
Without locking diffs all you ever get in 4WD at most is power to 2 wheels, one front one rear. In 4A conceivably , in theory. you could have power only to one front wheel except that the transfer case does not allow for 100% transfer of power from back to front.Seems like pretty standard stuff to me. 4WD as compared to AWD usually doesn't allow slip between the front and rear drive shaft so even with unlocked diff on each if the rear doesn't exactly match the front there will be tension wound up in the drive train which will cause hopping both of which can cause damage. Stuff in turning will be noticed as well.
Lockers just prevent differential from allowing slip which compounds the issue.
The mystery for me is that at Off Rodeo they had us go into 4WD while on pavement, and even drive some distance and around turns, on pavement. I noted that there was no tightness in steering nor skipping nor binding in drive train. That led me to conclude, that at least with the advanced trac transfer case that it had the equivalent of a differential between the front and rear axles or some sort of limited slip there. My non advance trac clearly does get tight and skip if I have it in 4WD on dry pavement and try to turn as I accidently did it once.
It sort of bothers me that the advance trac in 4WD seemed to allow slip between front and rear. In 4A yes I would want that, but not 4WD since if the transfer case allows front/rear slip when in 4WD one slipping wheel could get you stuck. Lockers can help that tho.
