California PROPER Security Bolt Kit - Baja Designs->SPV Brackets->Modular Front Bumper
swamp2
For Sale: Massively improved bolt kit for mounting one pair of Baja Designs LP4/LP6/LP9 to the Modular Front Bumper via SPV Mount. The nicest lights and mounting brackets deserve the best mounting bolts with theft protection.
TL/DR - All stainless steel bolts, proper lengths and full security bolts
Details:
Unfortunately, the hardware from Baja Designs for mounting the LP series lights on the Modular front bumper via the SPV Mounts kit is quite inadequate. The issue is, in part, that Baja Designs did not account for mounting brackets as thick as these beefy "double" brackets from SPV. SPV also chose not to provide any hardware, which in my humble opinion they should have. There are 3 main issues this kit addressees:
  1. Bolt lengths - not having the bolts bite into the nylock part of the nuts is simply wrong. The bolts must pass all the way through the nuts! Basic fastener spec-ing here.
  2. Washers: The washers provided by Baja Designs are not large enough for the slot size in the SPV mounting brackets. This is true for both the large center bolt and the "rotational tie down" bolts on both sides of the large center bolt. The kit provides all new washers here, 14 in total for the kit.
  3. SECURITY. Security bolts - Torx with central pin are provided for any way your lights might get stolen. 1 bolt for mounting the plates to the bumper (with special sized washer), 1 for mounting the light base to the SPV mount and 2 bolts per light at the high/low pivot adjustment points.
  4. Both the T40 and T27 Torx security L keys are provided.
Baja Designs wants $21 for a measley set of two security bolts with the inferior two pin head. These leave mulitple other places (2 in fact) to steal your lights with every day tools. No bueno. SPV wants $47 for just 4 security bolts to secure their light mount to the Modular Bumper.
Get this bolt kit for $55 + $5 S&H.
Right now only 1 kit is available, but I can build more if folks want/need. Just DM me.
This kit:
Ford Bronco PROPER Security Bolt Kit - Baja Designs->SPV Brackets->Modular Front Bumper PXL_20251213_211426409
Baja Design Security Bolt Kit
Ford Bronco PROPER Security Bolt Kit - Baja Designs->SPV Brackets->Modular Front Bumper Screenshot 2025-12-13 at 1.29.13 PM
SPV Security Bolt Kit:
Ford Bronco PROPER Security Bolt Kit - Baja Designs->SPV Brackets->Modular Front Bumper Screenshot 2025-12-13 at 1.30.16 PM
