Problems driving in sand
JaredWilm28401
Wilmington NC
2023 Bronco
After 5-10 minutes of driving in deep sand, it feels like I’m dragging an anchor behind me.
I’ve tried every drive mode, put it in 4wd low etc.
I get the “doom lights” advance trac disabled, drive modes disabled etc
I’ve manually shut traction control off and advanced trac by manually holding it down.
It’s like the parking brake stays on.
anyone else have this?
JaredWilm28401
JaredWilm28401
Wilmington NC
2023 Bronco
Driving in sand is challenging, and an art. First question, did you air down? You want to float on sand, not dig in.
I’ve aired down to 18lbs on the stock tires. I’ve recently added a 2in leveling kit, and stock Sasquatch wheels and tires. I’ve aired down with both setups. Same results. I’m not rubbing the underbelly or building sand in front of my tires, if that was the question.
Baja Bronco
2Sun AZ
18 seems fine. You tried sand, sport, Baja modes, and they all weren’t noticeably better?
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
The best I can tell you since you've already aired down is momentum is your friend when driving on sand, you need enough speed to keep going at a steady pace. Harsh braking and trying to go slow will just make you dig in.
JaredWilm28401
JaredWilm28401
Wilmington NC
2023 Bronco
I did. I don’t have Baja mode
I’ll add that I have experience in the Oregon dunes and driving in Alaskan deep snow for most of my life.
Its frustrating that my gf’s 2012 Hyundai Tucson doesn’t have issues going to the same places on the same beach. Lol
This has to be a sensor issue.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
I see your problem: big wide heavy Sasquatch tires with base 3.73 gears. You can’t get enough power to the wheels with such “tall” gears, especially if you have the 4 cylinder.
JaredWilm28401
JaredWilm28401
Wilmington NC
2023 Bronco
Y’all are great and I appreciate the help! I don’t want to come off that it’s not my fault, because it could be. But it’s probably not driver error.
Im hoping someone else has had this issue with their 7spd/2.3 can shed some light on some technical issues we may have with the bronco.
JaredWilm28401
JaredWilm28401
Wilmington NC
2023 Bronco
I don’t believe thats the case, because I had the same issue happen when I was all stock. 3 separate times before I did the adds. The 2.3
Hdscreens
Will
2dr Bronco Badlands
I know a Bronco Sport I had would easily cut through deep sand and much better at it than a gen 2 Raptor. I always would figure it was the lightweight of the sport cause the Raptor obviously has more power and capability.
JaredWilm28401
JaredWilm28401
Wilmington NC
2023 Bronco
I’ve sold a ton of bronco sports to folks that jam right through the same beach I’m having issues with! Lol
I certain it’s some kind of faulty sensor
Baja Bronco
2Sun AZ
Sand definitely isn’t the same at any 2 places. Sand in the Oregon dunes isn’t like Glamis, and Glamis isn’t like Little Sahara. Beach sand is different everywhere too. Some powdery, some harsh with crushed shells. Momentum is the key. But you should definitely be better than a Hyundai Tucson. Do you actually know if your 4wd system is functioning properly?
SuperDave150
Lubbock, TX
Wow it is worse than I thought - 4-cylinder, 3.73 gears, torque management.
Seriously though it is not just the 2.3 that lacks what I call “jump”. All turbo mills lack the low end grunt to plow thru soft sand. You gotta spool it up.
On the other hand, if you’re getting alarms or codes then take it to dealer for code scan.
redvettx2
Tom
Scottsdale, AZ
05 Maserati Coupe GT,16 Jag F-Type S,65 Cobra 427
Go to low lock and gear up. You shouldn't have too but it will answer some questions about your power.
JaredWilm28401
JaredWilm28401
Wilmington NC
2023 Bronco
Yessir. I’m sure the 4wd is engaging properly. I tried to use 2wd after I had these issues (to see if it was stuck somehow) out there, I dug up to the axles. I tested that and put it back in 4wd and it came right out but with extreme resistance. I wasn’t even kind of stuck. I’ve tested my 4wd on gravel and it walks on me like it should.
