Pre-made Wiring Harness for Adding Amps
Skeletor
WV
My Whip
Hey everyone. I'm a complete novice when it comes to car audio. I've dabbled in the past, but that was years ago. So? I really have little to no knowledge other than what I've recently read and researched.
During my searches I ran across this:
https://lljcustoms.com/collections/oem-loopback-style/products/2018-2023-select-ford-elite-harness
Anyone have any experience using something like this? Are these common place? My Bronco of the future will have the base sound system, and I'm looking yo upgrade all of the component speakers and add an amp for then. Also looking to add a small compact sub.
Will this harness work for that?
Thanks for the input!
da_jokker
Jeep Wrangler JKUR
I'd be interested in this as well, but like you I haven't installed a stereo system in years.
So others may have better feedback, but at some point crutchfield will have all the information you need, regardless if you actually buy from them or not.
Or sooner or later someone's going to pull out the radio here on B6G and you'll see if those plugs are in the back.
Inrustwetrust_
Alex
Peoples Republic of Massachusetts
2021 Bronco 2dr
Definitely following this for more info. Id love to be able to add an amp without cutting into any of the factory wiring.
WuNgUn
Ontario Canada
2 door Squatched
That's pretty cool... Of course, you probably gotta mount your amp somewhere close to the HU...?
This would be better suited to the B&O system, as the HU has a sub out whereas the base unit doesn't.
I'll probably just go with a, speaker upgrade.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Made my own pigtails for the aux switches so you can quick disco and pick which switch you want to use.
Ford Bronco Pre-made Wiring Harness for Adding Amps 1A72A085-3157-402F-9967-4C83B45019CA
Skeletor
Skeletor
WV
My Whip
I was thinking of putting the sub under the driver's seat. One if those 8" or slightly bigger all in one subs. Nothing crazy. Just enough for good sound.
I was then thinking about installing the component amp under the passenger seat.
Then all I'd have to run I'd power from the battery, and splice the sun into the 6.5s in the kick panels.
I'm sure I'm missing something though.
Skeletor
Skeletor
WV
My Whip
It's gona be a while until I get my Bronco, so I've got time to wait for things to develop, but if this helps someone figure their system out sooner, that'd be cool too.
