Power Steps
kahunabob
Bob
Santa Clarita, CA
4runner
Maybe Rocksliders will make a Bronco Version;
I had these on my Jeep LJ. Made to be bashed on the rocks! Stout! The driver side worked well...but the passenger side would need to be reset (did not drop when the door opened) on a regular basis (pull the fuse)...Also, they make a huge 'clunk' sound when they close. There is also an on/off switch so that they can deactivated on the trails. No worry about opening on the rocks.
The AMP research are quieter and seem to work flawlessly....but I don't think they will stand up to a big hit on the rocks?
Granger Ford
Jay
Granger,IA
www.grangerford.com
I did a little more checking on this and saw on the F-150 forum that a company named Mytox now makes Fords power steps boards. Funny thing is they have to pay royalties to Amp Research because they are using their design. Even so, parts don't interchange between the 2. I don't know how mine were Amp Research on a 16 Expedition when the person that posted had an 11 F-150 Limited? He had complained about problems, but they always worked when at the dealer, so they wouldn't do anything. One finally died a month after the warranty expired and the dealer replaced them due to the customer complaining while still in warranty. They said Ford charges almost $3k for them, but most people replace with real Amp Research that can be bought as low as $1200, plus you will be able to get replacement parts.
Exactly Ford gets 1500 per side on the boards...
Amp Research can be rebuilt with parts easier...
I just maintain mine so they work when I get rid of it...
attworth
Tony
2000 Land Rover D2
I sent a request to them to see if they were contemplating the Bronco...
I am familiar with them and Rock Slide Engineering (Jeep only) produces a great product.
Albert, theres very preliminary plans in the works for me to drop my 4-door off at RSE when I get it so they can use it. If you can somehow push my order to the front, we can get these to market faster.:LOL:
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I read some reviews on the AMP research. I like the way they look and function and I won’t likely do many rocks. Two downsides for me I need to consider (assuring they become available) are salt spray and they are not waterproof. They are susceptible to damage if submerged. Although I don’t often ford deep water, there are times in the spring it will be very possible, even on two tracks I will traverse. Maybe they have newer models or will add a water rated motor for the Bronco. I also have second hand experience with the power steps failing after spending a few years in the MI salt slurry we experience every winter.
acetdeucy
daniel
Lincoln Corsair Lexus RX350
When you purchase Jeep Steps through AMP, you can choose Standard (height) motors or +3" motors (the XL model, for lifted vehicles).
I've contacted AMP, and asked them : based on the difference in step-in height from the +3" lifted Jeep to the Sasquatch(ed) 3" lifted Bronco (the Bronco appears to be about 1" lower step-in), will they consider to also make a +2" motor in their XL Bronco Power Step? My only response has been that they haven't had an opportunity to measure the new Bronco for height or to confirm the bolt pattern on the new frame.
Granger Ford
Jay
Granger,IA
www.grangerford.com
I have not had them, and most of the Jeep customers we have put rock rails or cheap running boards...
I personally had one with the rock rail and power steps that made it easier for my wife and daughter to enter, just made the back of my pants dirty at 6'2"...
acetdeucy
daniel
Yeah, I hear ya... I'm also 6' 2" and I'm able to get in a Jeep (I've had 3-Wranglers) comfortably. Unfortunately for this Jeep/Bronco lover, my wife is 4' 10." If they made an elevator, I'd have to get it!!!
acetdeucy
daniel
Is Ford sending testers to aftermarket companies?
I talked to Amp about two weeks ago. They said that they haven’t seen a Bronco yet... and that they must be able to have one to complete the design (for accurate measurements) for the work associated with all of their products.
SFNMutt
Philly
2014 JKU Rubicon, 2012 Mustang GT vert
My wife grumbles about getting into my Jeep but at least she's in the front seat. It's my mother-in-law climbing into the back that I feel bad for. She never complains but I know it must suck. The power dropdown rock rail steps will be a must have for me.
That'd be useful. Especially since I didnt consider whether or not my wife can comfortably enter and exit this thing . . .
Las Vegas
2020 F350 DRW, 2015 4dr Jeep, 1997 F350, & more
Opens when the door is opened... I guess your SOL with the doors off?
For the Jeep, Amp Research power steps sells a simple relay. When you take the doors off the steps stay down, press the lock button twice and steps retract.... simple technology
Las Vegas
So, some of you are saying use th Aux switches inside the vehicle to deploy when the doors are off, wouldn't that entail getting into the vehicle first to deploy the step to help you get in the vehicle?
I have had the AMP steps on my Superduty for ~7-8 years now and have not had 1 problem (hope I didn't just jinx myself). Great addition and they have held up well to plenty of snow, ice, dirt, mud, etc. I think at least originally the OEM'd for Ford for the F150s, not sure about lately though.
For Jeep, AMP sells a relay, just click the lock button twice with the doors off to retractor deploy
