- Gary
- Aug 18, 2024
- 36
- 568
- 477
- Costa Mesa CA
- 2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
- Badlands
I am pretty sure I have been able to turn the power port in the rear to the "always on" mode. I did it in FORScan in the BdyCM module under "As Built" 726-57-01. The fix was xxxx-00xx-xxxx.
Originally it would time out after exiting the vehicle or turning the engine off. I tried a few things to change that and it would then shut off when I turned off the power. With the changes above, it seems to be on all the time. Every time I check it it has power. I just hope that it does not turn on when I open the door. I now have a 120V converter plugged into it that draws a little power. It has a light on it that I can see without opening a door. That should confirm if it is truly always on.
