Possible B&O system Co-ax outputs?
BigMeatsBronco
Allan
2021 FE 2 door
So while chopping my Bronco up and moving electronics outta the bed area (yes it has a bed now) I noticed on the B&O amp, a plug with four connections....
Immediately I thought ”I bet these are for co-ax low outputs”!
Never seen a connection plug quite this size and shape, but found it also interesting that the blue wire uses a USB connector plug.
Here's a pic.
Anyone have a test kit to see if these are indeed line outs?
Ford Bronco Possible B&O system  Co-ax outputs? 20220411_114224
Ford Bronco Possible B&O system  Co-ax outputs? 20220411_114148
Ksjrb03
Tx
F250
The blue wire is head unit to DSP connection. The other is a service port.
