I'm ready to replace my front dash speakers too. Wfich speakers did you buy and how do they sound? Thanks !!
the sound significantly better! I really didn’t think stock sounded that bad (I just adjusted the EQ towards more mid and bass and less treble. But after hearing the difference with these it’s incredible I keep the bass, mid, and treble all equal. Attached is a video with the stock vs the kicker CSC4I'm ready to replace my front dash speakers too. Wfich speakers did you buy and how do they sound? Thanks !!
I think what you're talking about is where it changes from the module harness to the speaker harnesses. "Cxxx" = connector # and those dashes indicate a break (for the connector).Ehh, even with that through lesson It still isnt making sense to me. I wired mine a long time ago, showed my certified industrial electrician and he was stumped. Reading left to right I do see:
LF+ --> blue wire (kick panel)
LF- --> Gray-Brown.
These are on the same channel (similar to JKU)THEN two outcomes which isnt clear to me.
Blue turns into gray-blue or green blue? conversely
Gray brown turns into gray blue or green blue.
I see there are numbers 3,2,1,4 and the dash has 1,3... so seeing how the kick panel has a 1 and thus the dash has a 1, safe to assume the 1 would be your positive?
After a headache i just called crutchfield and had them help me![]()
Great! I'll order those speakers tonight. I definatley can hear the difference !the sound significantly better! I really didn’t think stock sounded that bad (I just adjusted the EQ towards more mid and bass and less treble. But after hearing the difference with these it’s incredible I keep the bass, mid, and treble all equal. Attached is a video with the stock vs the kicker CSC4
