Portable, under hood compressor for one wheel at a time?
midcont
N.J.
Gladiator
What's a good portable compressor that I can hook up to the battery (don't want to carry rechargeable batteries) that will do one tire at a time? I don't want to be laying hoses all over the ground and having to roll them up again for storage.
I'd love a setup that let's me hook up, set a pressure, and walk away and will stop filling and stop the compressor when set pressure is reached.
Everything I'm seeing has a compromise in one area or another.
midcont
N.J.
Gladiator
I watched it...jumped ahead a bit but pretty sure what I describe is not there. At least not all attributes of it.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I have a Husky I plug into my "accessory plug" (cough cigarette lighter) that I've had for several years now. It works, but it's slow, especially when it's below freezing. It has the set-it-and-forget-it. (I also have the MORRFlate TenSix with four hose setup.)
I don't see that one around anymore, but this one looks very similar:
https://www.homedepot.com/p/Husky-120-Volt-Inflator-H120N/325096203
Neither one of those I would leave in the engine compartment; they might melt.
The set-it-and-forget-it on the premium "off road" branded compressors like MORRFlate or whatnot are expensive. Here's MORRFlate's standalone attachment, if you have the right hose coming off the compressor, which is $250:
https://morrflate.com/shop/morrflat...tion-deflation/air-hub-automagic-air-control/
If you can find a single Viair that moves 2+psi of air and has an auto shutoff, that's probably what you're looking for.
If you're looking for engine bay mounts, there's this:
https://www.bronco6g.com/forum/threads/best-on-board-air-compressor-mount.78981/
One that mounts in the rear door itself:
https://www.bronco6g.com/forum/thre...-lab-tailgate-air-compressor-installed.87313/
And a tailgate version with a Viair (which is nice):
https://iagoffroad.com/iag-tailgate-air-compressor-system-2021-ford-bronco/
Me personally, I'd suggest the MORRFlate FiveSix with two tires, but you still got the two hoses to wrangle.
