THE_SAVSQCH
THE_SAVSQCH
Savas
Central Connecticut
2024 Bronco Raptor
Ya could have mounted the compressor in the back - we sell a power extension :) I like a mounted air compressor - takes up less room although in a raptor it gets mounted inside
Out DD kit has lights with the amber back light that match it: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/fog-lights/
I’ll call you guys and order right ones. Doesn’t it work with the fog switch in car and real bright one to upfitter?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
on a raptor one pair is controlled form fog switch and pairs 2 and 3 from upfitters
THE_SAVSQCH
THE_SAVSQCH
Savas
Central Connecticut
2024 Bronco Raptor
And that is why I buy all my stuff from you guys. If you look at case closely we put in the air control module bought from you guys.
I hope someday take ferry over and visit one day. Get the lights in person and meet the crew.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Bring your wallet. It's like a candy store for adults here :)
Depending on the time of day it's sometimes quicker to just drive around. It's an hour ferry from Bridgeport and then we're about another half hour from Bridgeport (we're on the south shore). BUT it's a nice break to sit on the ferry. I usually get one of their crappy hamburgers to help pass the time
THE_SAVSQCH
THE_SAVSQCH
Savas
Central Connecticut
2024 Bronco Raptor
I’ll head over for sure. We can make a post β€œDay with the Team at 4x4TruckLed”.
no worries you guys will get more of my moolah πŸ˜‚
wgw
bill
Va
2023 Black Diamond Bronco
Edit: Sold the Wildtrak which I had mounted with 4x4led bracket. Bought Raptor that I didn’t want mount in back so have this solution instead. - BBR
β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”-
Hi everyone it’s BBR πŸ‘‹,
When I sold the Wildtrak I discovered you can’t mount the dual ARB in engine bay because of how it’s setup.
Saw a friends awesome setup he put in trunk etc but wanted a different solution, because I tend to change vehicle every few years.
Attached are photos of dual ARB I bought from a company (name escapes me sorry) and then my buddy @Dubsesd connected the ARB air control module for use by ARB app.
BBR πŸ‘‹ πŸ‘‹ πŸ‘‹
Fuse size please
THE_SAVSQCH
THE_SAVSQCH
Savas
Central Connecticut
2024 Bronco Raptor
Fuse size please
Off top of my head no idea but I’ll take better pic and post it up for you in few hours.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
ARB Twin Air Compressors utilize Dual 40 amp fuses
hollapm
Paul
SoCal
2021 Bronco First Edition, 2021 Ranger, 2024 F250
I created something similar, although I have a 1 gallon tank, pulleys and straps also in the β€œair box”. It’s the same one included in the portable ARB box. The other packout contains impact, driver and battery. I also have a rail in my vehicle to keep these secured when off roading.
Ford Bronco Portable ARB Air Compressor solution in Milwaukee Packout image
Valhalla
Valhalla
Chattanooga Tn
I like the rail, If you have ever rolled, tools flying makes time stop.
THE_SAVSQCH
THE_SAVSQCH
Savas
Central Connecticut
2024 Bronco Raptor
I created something similar, although I have a 1 gallon tank, pulleys and straps also in the air box. It’s the someone sent it to hard box. The other packout contains impact, driver and battery. I also have a rail in my vehicle to keep these secured when off roading.
That is awesome! I have MORRFlate as well. Adding the air control module to what the off-road site assembled was game changing.
I love the flexibility of having it portable rather than how my Wildtrak had under hood.
hollapm
Paul
SoCal
Fully agree, I don’t want anything moving around when it’s not suppose to.
Showing the rails as well as in the right side of the picture the plug for the ARB.
hollapm
Paul
SoCal
Agree, the control module makes it so much easier. Reminds me of the air fill up at Costco. Set it and forget it. I also have the quick deflate valves, can drop my 37’s from 38 - 18 psi in about 18 seconds.
THE_SAVSQCH
THE_SAVSQCH
Savas
Central Connecticut
2024 Bronco Raptor
whoa can you link them?
hollapm
Paul
SoCal
Apex Designs - these are fantastic. I use to use the STAAB declarers but these are so. Much faster and nicer. When I installed them it took a little persuading to get the TPMS sensor aligned but got it working.
Apex Designs RPV XL. You need the XL for the factory wheels with real headlocks. I wish they were a little longer or the cap was a little longer but I’m able to get my fingers in to remove them. Just don’t overtighten them :)
