Poll:trim change i.e.:base to badlands
Will you keep your reservation if you can't change model/trim?
  • Yes
  • No
  • No?: buying a jeep instead!
Results are only viewable after voting.
Jackattack
Jarmon
LA
Bullsh
Noticing a lot of questions and lack of evident proof that you can or cannot change model/trim when ordering! Getting the poll going in case Ford sais NO. We may be able to use it to leverage a change!
I reserved a big bend and dont want that at all! Badlands or black diamond. Will you keep your reservation if they don't allow you to change?
Jackattack
Jarmon
LA
Bullsh
BTW I will be calling Ford customer relations Monday. The same number I called to change my dealership reservation and ask if I can change my model/trim.
BroncoFanBoy
Brandon
Az
Nissan
Can you define the question further? I can’t imagine them changing their mind this late and not letting you change trim. By model do you mean bronco sport vs full size bronco?
Jackattack
Jarmon
LA
Bullsh
That better?
Thanks for the feedback!
BroncoKid
South Carolina
F250 & Titan
I am trying to figure out what ignorant metrosexual in Ford's marketing department came up with the package grouping?
They go through the trouble of developing a really good looking off road package and then refuse to sell it with a manual transmission and the suspension upgrade.
They even brag that most customers of this type of vehicle will spend thousands on upgrades but they won't let their customers select individual options.
Is it too much to ask for a base model (or any model) with the suspension upgrade and a manual transmission? Are all of Fords marketing weenies driving around automatic Echosports, with a five o'clock shadow and flannel shirts thinking they are the epidemy of a backwoodsman but have never slept on a mountain top in a tent, outside of cell range?
Reldn
MO
'23 OBX Squatch, '22 Ram 1500, '22 Chevy Blazer
If it does happen that we're locked into what we reserved. Then, I would probably keep my Black Diamond reservation. It wouldn't be too different from the Big Bend build I'm aiming for, so, not a huge issue.
Jackattack
Jarmon
LA
Bullsh
This is a silly question, its already been confirmed when you place your order you can order whichever one you want except the FE of course.
Can you please show where Ford has stated this seperate from a dealership?
RG7
B8 A4, 2018 Triumph Street Triple R
Not sure what you’re on about, Sasquatch is available with MT, just not on the B&P because it’s late availability
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
A lot of places, including the emails you receive. Reserving a trim or even door count doesn't mean anything unless you're a FE holder. You can change your mind as much as you want until you fill out the order sheet. Then it's a done deal (for the most part).
Per Ford's FAQ:
Ford Bronco Poll:trim change i.e.:base to badlands 1603598470200
BroncoKid
South Carolina
F250 & Titan
Try configuring a Base two door with the four cylinder engine and select the suspension upgrade. Then scroll up and check the transmission, it will have been changed to an automatic. If you the selection the manual transmission, it will remove the Sasquatch upgrade.
Reldn
MO
I had it confirmed when I called to change to a different dealership. I asked them at that point if when it came time to order if I could change to a different trim or if I'd need to place a new reservation (at the point a Black Diamond to a Wildtrak) and was told that when we were called to change our reservation into an order then we can configure it however we'd like. From a 2 door to a 4 door, Base to Badlands. So long as it's not a First Edition we can change to whatever trim we want.
Incognito
Phoenix
2017 jk
Do you understand what " Late Availability" actually means? :rolleyes: :cautious:
Gird your loins for not seeing a Mansquatch until 2022MY.
If you can't wait that long, for whatever reason, get the 10A and live with it.
  • Like
Reactions: RG7
Jackattack
Jarmon
LA
Bullsh
Per Ford's FAQ:
From a legal standpoint, they can change their mind to meet demand and there's nothing we can do about it. Also, that and its disclaimer connected annotation state nothing specific to changing the trim. That could be only referring to the door selection. My point being, nothing definitive has been stated. You could also be right. I hope you are!
RG7
Just gonna repeat my first post because you clearly didn’t read it:
