Plug and Play Fog Lights
mannyjag
Manny
SoCal
I know this questions has been asked plenty of times. Just bought a Mod Bumper from another Bronco owner and I would like a list of aftermarket fog lights that are plug and play to my factory fog light switch. Links to other pages are welcome. I've been looking at the following:
https://www.roughcountry.com/ford-b...html?find=2022-ford-bronco-4wd-856075#280=709
https://www.4wheelparts.com/p/oracle-lighting-led-fog-light-kits/prod9690002
Just not certain if they are plug and play or if I need to buy a separate harness.
Thank you in Advance!
da_jokker
Jeep Wrangler JKUR
You can buy the plug adapter for less than $20 which makes pretty much any fog light plug and play.
Just make sure not to buy fog lights that are so powerful they take too many amps.
FYI, I purchased Amazon plug adapters and fog lights for 35 bucks and they are plug and play :)
JTK37
New Jersey
2016 VW Golf R
I went with Diode Dynamics SS3 Pros that I got from @4x4TruckLEDs.com with their harness the electrical connections were literally plug and play with the stock fog wiring(I have a Wildtrak with the std bumper).
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
foremi
Bronco Badlands 2dr, Touareg V10, B5 S4 6spd Avant, YXZ
As other have said 4x4truckleds has adapters for most of the popular aftermarket pod lights and I have them for the diode dynamics pods.
I would be careful with some of the brackets from 4x4truckleds though... the KR offroad bracket I have (picture attached) does not allow you to properly aim the pods because the surrounding bezel severely limits how you can aim them. My Fogs are pointed at the sky if they are actually "in" the bezel so they have to be moved behind it and it looks aweful imo.
I would also be careful about the power draw of the fogs you wire to the factory fog lights wiring. The factory ones are not very powerful so you probably shouldn't attach 2x 40w pods to them.
Ford Bronco Plug and Play Fog Lights Bezel_Brackets__77203
Ford Bronco Plug and Play Fog Lights IMG-1556
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I bought the Rigid kit. I am a long time fan of Rigid. The SAE fogs are connected to the factory fog light switch using an adapter from 4x4TruckLEDs. The other four are wired to Aux switch 6.
Ford Bronco Plug and Play Fog Lights DA00918B-77D7-411D-90B7-D46C26A4B326
Ford Bronco Plug and Play Fog Lights AFD0B5AA-DDC4-425E-A9C6-293F2DB4FF21
Thart89
Tyler
Orlando
Explorer
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Any plans to make fog light kits for the capable bumper with round lights? I see you have some with square lights but really like the idea of keeping all the lights round.
We already sell a kit:
https://www.4x4truckleds.com/diode-...-fog-lamps-2021-ford-bronco-2019-ford-ranger/
We know these fit.
Otherwise, we don't plan to make a whole new kit just to change the bezels to round on our dual kit, sorry. It's not worth it. Also the round would not fit. And going to 1 single light... honestly no real sense since Diode already makes a kit that MIGHT fit (we tested it, it's tight, but it's also tight on the plastic bumper)
https://www.4x4truckleds.com/diode-...-for-2021-ford-bronco-plastic-capable-bumper/
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
I ordered diode dynamics elite series. The replace the factory fogs. Haven't installed them yet but they look like they're a lot brighter than factory. Waiting for the weather to break.
Thart89
Tyler
Orlando
Explorer
We know these fit.
Thanks for the quick response. That makes sense just wasn't sure if 2 round lights could be squeezed in or not. Thanks anyway
mannyjag
mannyjag
Manny
SoCal
Can you share the link to the plug adapters on Amazon?
TIA
mannyjag
mannyjag
Manny
SoCal
Thanks for the input! Do you have a link to the lights from Rigid?
cyberfalco
Tony
Conway, AR
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
Adam
Lindenhurst, NY
