Plug and Play AUX Controller?
Jenkins_Auto_Image
Dylan
Milan, IN
2012 Ram 1500, 2006 Acura TL, 2022 Bronco soon
Is anyone aware of any companies planning to create a "plug n play" AUX controller? I have been debating on buying the RC one designed for the Jeep, and adapting a mount for my bronco. Aside from the Jeep specific mount, it appears to be universal requiring only power and ground hookup
Ford Bronco Plug and Play AUX Controller? 52F07E9E-54A5-49DB-BFCE-01922577B095
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
Make sure to check the voltage/amp limit on that unit, if you really want a quality unit go with Switch Pros SP9100
Jenkins_Auto_Image
Jenkins_Auto_Image
Dylan
Milan, IN
I’m looking for something that is somewhat integrated into the truck without hacking much. Just to run a few pod lights. I texted rough country today and they say they have a mount for the bronco soon to be released.
Browp24
Paul
Hudson Valley, NY
2021 bronco
I was at the super celebration in Wisconsin and iag was selling basically what is below but it had its own mounting brackets that they sold with it. It was a little expensive but I bought out anyway. They said they would have more in 30 to 60 days
8 Gang Switch Panel Kit, Auto Power Plus Circuit Control Box Electronic Relay System Universal ON/Off Touch Switch Box with Harness and Label Stickers for Truck ATV UTV Boat Marine
Ford Bronco Plug and Play AUX Controller? 20220709_160203
Ford Bronco Plug and Play AUX Controller? 20220709_160152
Ford Bronco Plug and Play AUX Controller? 20220709_160149
Ford Bronco Plug and Play AUX Controller? 20220709_160138
Ford Bronco Plug and Play AUX Controller? 20220709_160135
Jenkins_Auto_Image
Jenkins_Auto_Image
Dylan
Milan, IN
Thanks for the replies everyone! I texted Rough Country and they finally got back to me today. I was told they have an MLC-6 integrated kit coming out very soon for the broncos. Hopefully it looks as flush as the jeep one.
xim
Wisconsin
'21 Bronco Big Bend
Thanks for posting these pics. I bought just the mounts from them and have been trying to figure out where they're intended!
Browp24
Paul
Hudson Valley, NY
2021 bronco
No problem. Have you figured out how the wire runs from the unit into the engine compartment? I am waiting for them to send the full directions
xim
Wisconsin
'21 Bronco Big Bend
Yes, there's a grommet that comes under the driver's get under the dash. Pops right out, put a small hole in it and shove the wire through and put it back. Works slick one you see it
Edit: added picture
Ford Bronco Plug and Play AUX Controller? 83FC79AC-2609-4D6B-9656-53774DE9F434~2
Browp24
Paul
Hudson Valley, NY
2021 bronco
Edit: added picture
Thanks so much! I have been waiting like a month to try and figure this out. I really appreciate it.
xim
Wisconsin
'21 Bronco Big Bend
Yeah man. Took me a while to find it too. Stumbled on it one day by accident.
Browp24
Paul
Hudson Valley, NY
2021 bronco
I actually just got an email from IAG that they will be sending the directions to me and that they are just finishing them up. I can share them when I get them if you need them. Also just a last question. Do you plan on running the cord behind the grab handle or does it run just down the side of the center console?
Thanks
xim
Wisconsin
'21 Bronco Big Bend
Thanks
I'll try to take a picture of it if I can get a good one. I just kinda tucked it in by the lower dash pieces, and ran it up along the handle for now. I had an extension cable for the auxbeam that I added as well, and that's coiled up behind it on the dash
Browp24
Paul
Hudson Valley, NY
2021 bronco
Thanks...were the wires that came with the mount not long enough?
xim
Wisconsin
'21 Bronco Big Bend
I didn't have the mounts when I wired. So my under the hood things are in different places. I'm hoping to modify what I have to more like the mount intentions, might not need the extension then.
My wires along side of the dash
Ford Bronco Plug and Play AUX Controller? PXL_20220802_170249946
