Pinout or diagram
jwhisl
James
Oklahoma
2025 Bronco
Not sure if this should go here or under lighting, but I am looking for a pinout for the side mirror harness. There are more wires on the vehicle side than the mirror side so that leads me to believe I could upgrade my base mirrors. Yes I searched.
zuke
Stafford VA
Check this thread; https://www.bronco6g.com/forum/threads/side-mirrors-turn-indicators-is-it-a-lux-package-item.62507/
You'll find both Pin outs and diagrams in the thread, Understand that even though the wiring may be there in the first connector, it may not go anywhere of use, as some of it comes from the individual door modules, some of it goes to the BCM, and some to the ECU... Also if you're trying to upgrade some of those features, it could require forscan programing, (For lights) and some things you would need different modules and a different headlight switch to accommodate, Like zone lighting for puddle lights.. There's a lot going on in the lux mirrors that requires things the base model doesn't have hardware to support.
