Pilar light mounts
Bronco671
Tim
Washougal
69 Bronco, Ram 1500
I have been looking at videos and pictures of the pillar mount lights built by a many different companies(BD,DD,KC and Rigid). I don't like the look of the lights mounting directly on the cowl.
The Body Guard mount looks really nice, Are there other kits that actually have a cowl mounting plate?
I see BD has one but watched a video and it looked like it wasn't included. Seems everyone's light kits are just a little different.
Anyone else using different brackets, pictures would be nice.
PWillette
Parrie
Maine
You can purchase the bodyguard brackets separately, $75/pr. I haven't seen anything similar from others
VelocityBronco
E
I bought my Baja Designs pillar kit from @4x4TruckLEDs.com and it came with the mounting plate that uses the 2 Bronco screws and has a threaded stud to mount the light bracket on. Also came with full wire harness, additional lenses and some rubber strips for mounting too. It was a very nice kit, I would recommend 10/10.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Almost every kit out there mounts to the exact same points on the mirror area. Baja Designs provides an 'off-set' plate which is NOT required to install the lights unless you have their bigger XL Series. Some folks use it because it does off-set them a little bit.
Here are two videos showing the Baja Designs pillar lights installed
Both used the Baja Designs lights: https://www.4x4truckleds.com/baja-designs-a-pillar-kit-for-2021-ford-bronco/
You can also get the Diode Dynamics lights as well which install very similar: https://www.4x4truckleds.com/diode-dynamics-stage-series-ss3-ditch-light-kit-for-2021-ford-bronco/
Pickens Party of 5 showed the installation if you DO NOT have upfitters. And CoderMan showed the installation if you DO Have upfitters.
stbanning
sean
Bonney Lake
f150 platinum, mazdaspeed miata
I have the Motobuilt brackets. They set up a little higher and out a little further. Very stout But, they do come unpainted, which i didnt realize.
Ford Bronco Pilar light mounts 20220107_100920
Ford Bronco Pilar light mounts 20220107_100924
cf_davey
MAP
Cyber truck
I bought Heretic personally. IMHO I believe they are the sharpest-looking lights available.
https://www.hereticstudio.com/?gcli...6vLMi0nd5M2fR7TVRmM945miU2jDkxOBoCx3gQAvD_BwE
I have NO connection to them whatsoever, except that they are from Utah. To me they are sexy and I can't wait to get them on my Bronco. I bought the light bar and the ditch lights.
Herbie
Alex
Cleveland OH
2022 Badlands
These raise them and allow you to add multiple lights if that is of interest.
https://mountains2metal.com/product/bronco6g-apillardualsxs/
BroncoAZ
Mitch
4x4TruckLEDs.com
Adam
Lindenhurst, NY
BroncoAZ
Mitch
4x4TruckLEDs.com
Adam
Lindenhurst, NY
BroncoAZ
Mitch
Check out our kits than - made here in the USA and (as far as I know) we are the only ones who use stainless steel for our brackets AND powder cost them (so it’s not just normal steel that can rust)
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
I’m a fan of your products and ordered some DD lights from you last month. I’m not questioning quality of your brackets, I’m sure they are great. I would like to find a bracket that doesn’t bolt to the top inside of the holes in the mod bumper.
Smheard
Sean
Jenks, Oklahoma
‘19 Raptor, ‘21 Macan S, ‘22 Big Bend, '21 FE
