Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
I'm not happy about the tow points. Doesn't look strong enough to tow the vehicle 4-down using that attachment point. Tow hook points should have the bolt sheer not the thread strip for failure. We shall see, but this will need some modification as it is now before I'm comfortable towing this around.
Bronc-OH
New York
Jeep XK, Jeep WJ
God, I would hate to have to replace those front diff bushings.... My xk has gone through 2 sets.
LandCruiser
Bocephias
CA
Anyone notice the 6 donut rubber isolators on the outboard edges of the frame (5 visable), I assume those are the body mounting points?
Yeah. You drop the body on those pucks.
Bronco4lyfe85
William
2019 Challenger Scat Pack
It appears to be a frame, yes.
Ford Bronco Pics: Bronco Frame, Chassis and Suspension 1601772435226
Bronc-OH
New York
Jeep XK, Jeep WJ
Bronc-OH
New York
Jeep XK, Jeep WJ
I got 110 out of originals. 37 out of the replacements. I guess that's not bad.
Lab00Rat
MS
pan-y-cerveza
Manitoba
Tacoma Pro
Those are not 3/4 inch. And the weld better never rust too.
Those bolts look barely over 1/4 inch.
3/8" would have been my guess.... But yeah... Not 3/4''
I'd be ok using 3/8"
Almost 3 times the strength of a 1/4" bolt.
buzpro
Binky
Tacoma
so can anyone tell where the oil filter is?
ekim
NJ
Jeep TJ, Ford Excursion
Yea, there was some speculation that the OEM D-Rings might be able to be used - but they mount to that same part you're looking at :-(.
There may be some hope. I'd like to see how this ring is attached:
Ford Bronco Pics: Bronco Frame, Chassis and Suspension bronco_parts_09-jpg
Lewisj41
Lewisj41
Jesse
Maryland
2017 Tacoma
Fuel tank is on passenger side, but filler on driver side. Interesting.
Guess they learned their lesson from the 1971 Ford Pinto days....
