Pedal Commander Throttle Response Controller Now Available
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Available Here: https://www.4x4truckleds.com/pedal-commander-pc18-bluetooth-throttle-response-controller/
If you own a Bronco, then you are well aware of the irritating delay when you press your gas pedal. Ford produces their trucks with a "one size fits all" process in an attempt to make most customers happy. For lack of a better term, they make the vehicle “idiot-proof. Not only do they limit how much the throttle body will open, but they also have a set limit on how fast the throttle body will open. In other words, it doesn’t really matter how fast you are flooring the gas pedal, your foot will not be able to make the throttle body faster. Pedal Commander solves this problem and gives you complete customization control over how you want your gas pedal to respond. Pedal Commander PC18 outfits all Bronco trim models with years 2021+ for engine sizes: 2.3L 2.7L 2.0L 1.5L
Why Your Bronco Needs a Pedal Commander PC18
  • Eliminate that annoying response delay from your Bronco's gas pedal.
  • Easy Plug-and-Play installation. Pedal Commander connects inline between ECU, accelerator pedal sensor, and throttle body.
  • The Pedal Commander is 100% reversible making it warranty friendly.
  • Easier access to change the setting through your smartphone with Bluetooth without having to physically bend over to do it.
  • Our Pedal Commander units are manufactured to the highest quality and standards with CE and TUV Certification.
  • 2-year product warranty.
  • It comes with 36 sensitivity settings so you will have complete control over how your Truck's gas pedal responds with acceleration.
How Pedal Commander Works
Pedal Commander connects inline between the accelerator pedal sensor and ECU which controls the throttle body. The Pedal commander is an adjustable amplifier for your gas pedal.
  • Pedal Commander will allow you to control your throttle MAP, allowing you to open your throttle 50% instead of 25% along with start and endpoint.
  • Pedal Commander's processor and other components are automotive grades and one of the most advanced and fastest processors on the market. So we are confident no one can match our performance and quality.
Can your factory Eco, Sport, Sport+ settings do the same? No, your factory setting has 1 map and that speed is limited by your ECUs processor speed. Pedal Commander will work hand-in-hand with your factory settings to give you complete control over your gas pedal's response.
With 4 programs and 9 different levels in total 36 different settings, Pedal Commander gives drivers the ability to have full control over how they want their gas pedal to respond. Pedal Commander is also equipped with Bluetooth, so you can download our app, tuck away the pedal commander, and just use the app to control the sensitivity.
Ford Bronco Pedal Commander Throttle Response Controller Now Available 1636608857172
Ford Bronco Pedal Commander Throttle Response Controller Now Available 1636608868492
shimmy825
James
Los Angeles
2017 Mazda CX-5
Is it easy to self install?
Schnabby
Tim
OC & JNLK, CA
JeepJL4dr,Raptor6.2,JeepJK2dr,M4Conv,65Must,74CJ5
Where did you velcro the controller? Is there enough room in the drivers footwell?
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
I like this. I will have to drive my Bronco for a bit to see if I need to change the response. Coming from an F350 dually, throttle response on anything is better than what I am used to. Now, once my turbo spools up, it will MOVE.
I will definitely add this to my future possibility list. Price seems very reasonable too. THanks for the info!!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Anywhere you want. Right to the dash is where I've installed mine before (on a Raptor)
Coloradonatives
Don
Fort Collins, Colorado
'69 Chevelle 2020 Chevy Traverse 2009 9-7x Aero
We have this on our 4Runner TRD Off-Road and it is about the ONLY thing that has made the Toy any fun at all. It works very well and took maybe 3 minutes to install. I am looking forward to input from Bronco owners before I install it, though.
MyBHinds
Kansas
1976 Bronco
Installed one over the weekend on my Bronco and I'm very impressed with the response. It does make it a lot of fun to drive for sure.
wjfawb0 [hacked account]
Tennessee
2015 Jeep Wrangler JKR
Torque management to stop warranty claims and improve fuel economy. I'm glad to see this is out there to overcome that stuff. Throttle by wire has a lot of advantages, but the implementation sucks for spirited driving and control freaks like myself. :LOL:
T-roy
Troy
Grand Island NE
2021 Base 4 Door
Does this one know when it is in reverse so it acts differently?
