- Adam
- Aug 30, 2021
- 553
- 6,152
- 7,047
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Available Here: https://www.4x4truckleds.com/pedal-commander-pc18-bluetooth-throttle-response-controller/
If you own a Bronco, then you are well aware of the irritating delay when you press your gas pedal. Ford produces their trucks with a "one size fits all" process in an attempt to make most customers happy. For lack of a better term, they make the vehicle “idiot-proof. Not only do they limit how much the throttle body will open, but they also have a set limit on how fast the throttle body will open. In other words, it doesn’t really matter how fast you are flooring the gas pedal, your foot will not be able to make the throttle body faster. Pedal Commander solves this problem and gives you complete customization control over how you want your gas pedal to respond. Pedal Commander PC18 outfits all Bronco trim models with years 2021+ for engine sizes: 2.3L 2.7L 2.0L 1.5L
Why Your Bronco Needs a Pedal Commander PC18
Pedal Commander connects inline between the accelerator pedal sensor and ECU which controls the throttle body. The Pedal commander is an adjustable amplifier for your gas pedal.
With 4 programs and 9 different levels in total 36 different settings, Pedal Commander gives drivers the ability to have full control over how they want their gas pedal to respond. Pedal Commander is also equipped with Bluetooth, so you can download our app, tuck away the pedal commander, and just use the app to control the sensitivity.
- Eliminate that annoying response delay from your Bronco's gas pedal.
- Easy Plug-and-Play installation. Pedal Commander connects inline between ECU, accelerator pedal sensor, and throttle body.
- The Pedal Commander is 100% reversible making it warranty friendly.
- Easier access to change the setting through your smartphone with Bluetooth without having to physically bend over to do it.
- Our Pedal Commander units are manufactured to the highest quality and standards with CE and TUV Certification.
- 2-year product warranty.
- It comes with 36 sensitivity settings so you will have complete control over how your Truck's gas pedal responds with acceleration.
- Pedal Commander will allow you to control your throttle MAP, allowing you to open your throttle 50% instead of 25% along with start and endpoint.
- Pedal Commander's processor and other components are automotive grades and one of the most advanced and fastest processors on the market. So we are confident no one can match our performance and quality.
