Passenger rear speaker stopped working
bcgray
Dallas, TX
2004 Subaru Outback Sport
Last summer I got the Kicker 200.4 amp, speaker pods from SSV Works with the kicker speakers and used Forscan to change the ACM module as below. Everything was working until some point this year when I noticed the passenger rear pod had no sound.
I unplugged the rear speakers and switched them to the opposide sides to test. The rear passenger still isn't producing sound.
I just double checked my Forscan settings and they are set as described below. Any ideas on where to troubleshoot next?
ACM727-01-01xx****xxxxxxxx*x-xxxx-xxxx - Driver Front Kick Panel/Dash Speakers
2 - Speaker & Tweeter
xxx*-xxxx-xxxx - Passenger Front Kick Panel/Dash Speakers
B - Speaker & Tweeter
xxxx-*xxx-xxxx - Passenger Rear Pod Speaker
0 - Speaker
xxxx-x*xx-xxxx - Driver Rear Pod Speaker & Subwoofer
0 - Speaker
727-01-02xx**xxxxxx--00 = EQS Flat EQ
cmtaz
AZ
2023 Bronco
That would infer that it's either the AMP (channel went bad / signal was lost) or the head unit / ACM stopped out putting to the pass rear channel.
To test this (and it will be a pain), if you take the input to the amp and pin some wires to it, connect it any old speaker (the original pods if you replaced them), that "should" answer if the ACM is outputting to the pass rear. You could also (maybe do this first :angel: check the input / output connections to the amp - that may be easier)
G/L
bcgray
bcgray
Dallas, TX
I ended up disconnecting the kicker 200.4 (what a pain) and the rear passenger works again.
I’m annoyed and relieved at the same time.
bcgray
bcgray
Dallas, TX
Looks like I should have posted this in a different thread since it’s unrelated to Forescan; bad assumption on my part.
@Administrator please move this thread if you see fit
