Panda Power Module question
Neptune44
Eastcoast
2024 Badlands SAS
Do I really need to replace the spark plugs that Panda sent me to use with the module? I don't plan to use the Race mode. They are the only company that sells a piggy-tuner that requests new sparks plugs that I know about.
No, not really. Ford ProCal is a (slightly) more aggressive tune I believe and doesn’t require it.
That said, I did notice a difference when I swapped the plugs - smoother idle for sure.
Neptune44
Neptune44
Eastcoast
2024 Badlands SAS
Thank you for the insight on your experience
If you have low miles, I would just save the plugs for when you hit 50 or 60k and then use them to swap out as routine maintenance.
Neptune44
Neptune44
Eastcoast
2024 Badlands SAS
That was what I was thinking about doing.
