Paint Matched OE Tow Hooks NOW AVAILABLE!
LethalPerformance
Jared
South Florida
www.lethalperformance.com
New to our Paint Matched lineup of products are the rear tow hooks!
Utilizing the OEM Hook & painted with OE Paint to match your vehicle’s factory color, these hooks maintain the same strength and function as your old hooks, ensuring the perfect blend of form and function.
https://www.lethalperformance.com/l...-tow-hook-2021-2026-bronco-bronco-raptor.html
Ford Bronco Paint Matched OE Tow Hooks NOW AVAILABLE! paint matched bronco tow hooks if
Features:
• OE Ford Tow Hook.
• Precision paint-matched finish for a seamless look.
• Direct replacement for easy installation.
• Ideal for off-road recovery and utility use.
They will fit all 2021-2026 Ford Bronco’s, including Raptor.
Note: Because of the paint-matched finish, using these hooks for towing, recovery, or any load-bearing applications may result in chips, scratches, or other cosmetic damage to the coating over time.
They DO NOT come with new hardware. Must re-use the factory hardware
Ford Bronco Paint Matched OE Tow Hooks NOW AVAILABLE! bronco tow hook paint matched 7
If you have any questions, feel free to reply or shoot us a message!
Dan-O
Dan
Fountain Hills, AZ
Hmmm…..paint…..? Why not powder coated? Considering their function powder coat would endure their use.
DsEighty3
Jacksonville, FL
www.b7vcklist3d.com
2019 M2 Comp / 2010 Yamaha R1 / 2024 Ducati SFV4S
I would assume that color matching exactly to be difficult, but i agree that powder would be more durable.
LethalPerformance
LethalPerformance
Jared
South Florida
There are definitely some advantages and disadvantages to powdercoating. It would be a more durable finish, however, powdercoating can still be damaged during a tow, especially if chains/metal are used to hook it.
The paint makes for an identical (or near) color matching to the OE paint and still carries some durability. During a tow/recovery, if you use a strap, rope, or some sort of a protective covering on the hook itself, the paint should remained unharmed.
We are currently only setup for paint matching at this time, but we will definitely be looking into powdercoating in the near future!
HalfmuleFarmer
Thomas
2025 Badlands
Real answer: tow hooks are just decorative on 98% of Broncos so who cares. Wear whatever earrings best match your skirt. 😎
