Paint bubble defects
BigfootArea51
Northeast
C5 Corvette
Anyone else notice bubbling like this in their rigs? Take a close look around. Not sure if it’s rust or run off.
Ford Bronco Paint bubble defects 37EFFEAF-C986-479E-A874-CA8AF3CE10CF
Ford Bronco Paint bubble defects 8DA3ABCC-E04A-4364-8894-3CC7B559ECEC
Ford Bronco Paint bubble defects 09ED25A6-82D9-4E15-868B-2BE7F03D7F43
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
Looks like sealer under the paint.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
I have an eye for paint defects after spending the last 20 years of my career in the Automotive Collision industry. I’ve taken a very close look at mine and my Eruption Green Bronco had just some minor issues with the metal flake orientation and a dozen small dirt nibs that were easily corrected with a DA sander and some compound/polish.
Those defects on your should never get past QC and the dealer will have to make it right by sending it to a body shop if they don’t have one of their own. I assume you noticed these right when you took delivery or shortly after.
BigfootArea51
BigfootArea51
Northeast
C5 Corvette
right after delivery of course. Leaving that untouched will that cause major issues down the road. If I were to keep the truck 10 years that is
Silver-Bolt
Eureka, MT
Looks like dirt/contamination under the paint. Long term, it could be a potential for rust. I would get it fixed.
KyTruckPlant
Goshen, Ky
I would get the dealer to fix it for sure, but isn't all of the exterior metal aluminum, so rust wouldn't be an issue?
Silver-Bolt
Eureka, MT
Aluminum will also corrode. Not the same as carbon steel, but it does corrode.
Ford Bronco Paint bubble defects aluminium-corrosion
KyTruckPlant
Goshen, Ky
When exposed to extreme salty conditions and/or due to dissimilar metals making contact (if other mitigation measures are not taken), I'm aware.
2 of those spots are on corners of class A metal that has been hemmed. Along any hem we apply a sealer, and if there is too much applied it leaks out of the seams, especially corners. It should have been caught in the paint dpt. before the prime booth.
