Paddle Shifters?
Merc4x4
steve
Has there been any news, leaks, speculation on availability of paddle shifters? I use the 'manual' mode of my auto trans a lot on the trails, but it's located on the console gear selector.
futzin'
Kentucky
Suburban 2500
I'd be in for that. I love them on my Honda Pioneer UTV.
Spooled
Republic of Texas
Raptor, Model 3
Speaking from first hand experience. Paddle shifting a 10 speed auto gets old. Quickly.
futzin'
Kentucky
Suburban 2500
Won't need all ten on the trail . . .
rmc523
South Florida
2022 Bronco Wildtrak
Yeah, I've used it a handful of times. It just isn't worth using.
If they're there, cool - might use them occasionally. If they're not, it's not the end of the world.
SaudiBronco
Saudi Arabia
Infiniti G37
The paddle shifters for the auto transmission is very important for such a vehicle designed primarily for Baja terrains. It is also very useful when it is used on sand dunes. The 150 Raptor is equipped with paddle shifters. Ford should consider them as least on the Wildtrak.
Ford Bronco Paddle Shifters? photo257
Jason
Jason
2023 Badlands & 2023 Expedition
I wish the Bronco had them. While descending on twisty mountain roads, using the paddles to control engine braking is much nicer than taking a hand off the wheel.
Merc4x4
Merc4x4
steve
This. Exactly my use case
RockEye
Jason
Atlanta, GA
2004 Subaru WRX STI, 2DR Badlands Reservation
I'm an engine brake junky in the mountains. I probably use it more than necessary. After you've driven through the Rockies a few times and every time you smell smoking brakes from people that don't understand this you make it a habit.
jtzako
Jason
Xterra Pro4x
In my xterra I manually disengage high gear going down long highway hills (like i-70) which should be easy enough on the 10spd gear buttons. I can manually select 1-2-3 as well using the shifter. The real issue is offroading. I dont want tiny buttons to switch between gears. Paddles could work but my preference would be actual gear lever selecting of gears not a thumb button.
Merc4x4
Merc4x4
steve
I'm afraid the engineers will want me to rely on clicking the hill descent control button. No thanks. Not needed. Just lock the trans in 1st gear. Much easier with paddle shifters.
