Oracle Headlights Won't Turn Off
OverlandingPastor
Louisiana
2012 Wrangler
I've had my Oracle Headlights installed since the first week I got my Bronco. Today I noticed the LED won't turn off after I exit the vehicle. They usually shut off after a minute or two but today they won't. They've been on for hours. Any ideas?
Ford Bronco Oracle Headlights Won't Turn Off 20240615_194306
OverlandingPastor
OverlandingPastor
Louisiana
2012 Wrangler
Put the factory ones back in before these set your house on fire.
Found multiple threads on this. Same thing happens to factory lights. I used the keyfob to lock the truck and they shutoff.
OverlandingPastor
OverlandingPastor
Louisiana
2012 Wrangler
Oracle has accounts here in B6g. Maybe ask them for help
btw, those headlights make a strange
Ford Bronco Oracle Headlights Won't Turn Off 1966-classic-ford-bronco-atlas-gray-302-series-passenger-front-34
Ford Bronco Oracle Headlights Won't Turn Off 20240329_191534
They look much closer to the 1966 lights the Heritage is modeled after than anything else I've seen.
HighVelocity
Big Sky Country
Pinto
Who cares? You can't see them from the drivers seat and the cheap ass electronics are downright dangerous. I don't understand the obsession with these things.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
I concur. My Oracle fog lights constantly fog up too.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Hello, the power channel for the Halos takes 5-10 minutes to shut down. they will turn off, just give them some time.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Dangerous? These lights are DOT and SAE tested and compliant. The vehicle is sending power to the lights, they lights can not generate their own power source (would be cool if they did) has nothing to do with the "electronics" in the light. Perhaps you can explain you misguided comment?
jsoa
Jose
Delaware
2024 Bronco 4dr
I've been noticing this too but just the side and turn signal lights that stay on, sometimes they turn off after a minute sometimes it's just the side markers that stay on and sometimes it's the side and turn light that stay on. Toggling lock and unlock a couple times usually turns them off but sucks that I have to check each time.
jsoa
Jose
Delaware
2024 Bronco 4dr
I've also noticed a white flash when using the color switcher (fade) when the bronco is on (doesn't happen when it's off)
Champ68
Champ
New Hampshire
2022 Bronco
What model year is yours? After several months off owning my 22' Big Bend I began experiencing a similar problem with my standard factory lights when the panel switch was set to Auto. Turned out to be a common problem with 21's and early 22 models as corrupted logic withn the panel switch caused the lights to either stay on after completely shutting down or would come back on a few minutes after shutting down. The dealer was aware of the issue and replaced the switch under warranty with corrected version and the problem has never returned. Refer to TSB SSM 50842.
Also, those Oracles look great. Wish the OEM lights looked like those. Would be closer to the first gen look.
jsoa
Jose
Delaware
2024 Bronco 4dr
Mine is a 2024, only started happening with the Oracle lights
