Oracle fog light install on Wildtrak--what did I do wrong?
Wildtrak24
Jonathan
Ohio
2024 Bronco
Just wired up some Oracle fogs to the factory plugs in the bumper. Bought a harness for proper plug and play functionality. Installed the fog switch, did the forscan thing...no power to lights or fog switch.
Maybe the harness wires were crossed? It was kind of a universal adapter. Not specifically for Oracle. My first thought was a fuse, but I understand that there isn't a fuse for the fogs.
What else should I be looking for? There are a whole bunch of options in forscan for the fogs. I only flipped the fogs to enable and switch to enable.
OracleLights
New Orleans, LA
www.oraclelights.com
Please take a moment to fill out our online tech support request here: https://www.oraclelights.com/pages/tech-support-form and someone from our technical department will be in contact with you shortly. Thank you!
Wildtrak24
Jonathan
Ohio
2024 Bronco
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Based on your comments if there is no power goign to the switch or the fog lights there is nothing on the fog light side that can be adjusted. You would need to review the instructions of the wiring adapter harness you installed (we are not familiar to what harness you are referring to). That would need to be corrected correctly and correct Forscan settings added to get power to the fog lights.
Wildtrak24
Jonathan
Ohio
2024 Bronco
Switch works fine. Fog indicator on the dash works fine.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Next troubleshooting step would be to check power at the harness output to confirm there is 12V at the harness output.
If there is power going to the fog lights the fog lights will turn on, that part is simple. The anomaly is the harness you are referring to and the Forscan stettings you are referring to.
