GucciFreshness
F150, Wrangler, Bronco
Had been told 37's wouldn't work with factory running boards so I ordered some Go Rhino RB20s. They are still shipping with wrong brackets and was told the right brackets are backordered with no expected date so I'm sending those back. I tried putting back on the factory steps and after sliding them back slightly they worked fine with zero rub. I just didn't like how low they hung down. I knew that body lift pucks were just poly and could hold a whole unibody so I just ordered a $20 professional cutting board to try since it only had to hold a step. It worked fine. 1/2 thick board doubled up raised the factory boards to exactly where the RB20s sat with just a small part of the pinch weld showing. I ordered some $40 one-inch matte black auto trim and put that behind the steps and now I'm happier than if I had the $500 Go Rhino boards because the tapered design of the RB20s left more space open between the flare and step for dirt and mud to come through. If anyone wants to try this themselves and wants some details just let me know. This forum helped me out a ton and I'd love to give back.
Ford Bronco Operation "Raise Factory Running Boards" 20230604_204031
Ford Bronco Operation "Raise Factory Running Boards" 20230604_204931
Ford Bronco Operation "Raise Factory Running Boards" 20230604_215704
Ford Bronco Operation "Raise Factory Running Boards" 20230604_220659
Ford Bronco Operation "Raise Factory Running Boards" 20230604_222909
Ford Bronco Operation "Raise Factory Running Boards" 20230605_092701
Ford Bronco Operation "Raise Factory Running Boards" 20230605_092738
Ford Bronco Operation "Raise Factory Running Boards" 20230606_145232
Ford Bronco Operation "Raise Factory Running Boards" 20230606_151237
GucciFreshness
GucciFreshness
Great idea and it looks much better. Do you have any after pictures from a higher angle? Just curious to see if it'll be more difficult to properly step on it.
I wear a size 13 shoe and it still works for me. The factory boards are pretty wide. Here is a pic I took to show how small the gap between the flare and board had gotten and it shows better how far the boards still stick out.
Ford Bronco Operation "Raise Factory Running Boards" 20230606_151925
kkenny
OH
2017 Mustang GT
Plus it hides the ugly spot-welds.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Great idea! Wish I would have thought of something like this before selling my OEM running boards and buying expensive rock slider combo steps. I actually like the OEM running boards. But I did gain a full 2 inches with my rock slider steps which is what I wanted, they’re all steel now, and fully hide the pinch weld, so I guess I still made out.
Thanks for posting!
lakesinai
Charleston SC
The marine industry has a UV Stabilized plastic boatbuilding product similar to your innovative use of cutting boards. Starboard. https://www.tapplastics.com/product/plastics/cut_to_size_plastic/king_starboard/526
BigFootie
Wisconsin
Here is an option for black marine grade material. McMaster-Carr.
Ford Bronco Operation "Raise Factory Running Boards" IMG_0949
GucciFreshness
GucciFreshness
When I put in the 18x12.5 board in 1/2 inch with rounded edges it comes back at $39.13 plus $19.29 shipping! I paid $20.12 with free shipping for the cutting board on Amazon. Just letting you know so you don't overpay. Thanks for the other option though
GucciFreshness
GucciFreshness
Tex
Cliff
San Angelo
Looks like it would be possible to simply remove the end caps, trim the ends off the running boards, then put the end caps back on to gain tire clearance.
cracKen
Washington
23 Bronco Badlands 7MT
Wow great mod for those with the cutting tools! Looks great too.
GucciFreshness
GucciFreshness
It was just easier to simply shift the boards back by loosening the bolts and move the brackets slightly. I didn't need alot of movement for no rub. I actually wanted the board as close as I could without touching to keep rocks off the doors. The lift had nothing to do with tire clearance. I just didn't like how low the boards hung and wanted them to block most of the pinch weld
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
Wow, OP that looks great, agree the stock OBX step hangs down too low. Will be looking into this when mine arrives. What fender badge is that? couldn't quite make it out, thanks...
Nevermind saw from your avatar it's a FE, looks great!
