Ok, time to pull the trigger: Squatch or no?
CWO4
Hubert, NC
F250, FX4
With all the additional weight of D & E rated tires, will the brakes need to be upgraded?
I would say no, from everything I have read here the brakes between a BL and a BL/SAS are the same and going from a 33" C (52lb) to a 33" E (58lb), a difference of 24lb total.
NoleDawg
Woodstock, GA
Ford Ranger
Most of us won’t see a SAS vs Non-SAS in person before we have to pull the trigger on our order. Are there any vehicles out there built stock that could be used as a comparative? For example, I’ve been thinking about going to look at a stock 2dr Rubicon (my understanding is the BL has same tire size) to get a sense at least for how I feel about the tire size/stance. I realize the ride will be completely different due to IFS so I won’t be messing with a test drive. I’m sure I’m not considering something here otherwise everyone in this same quandary would have already done this and got it all figured out.
Compta38
Alabama
Ford Fusion
no squatch on Badlands is fine and you can always stuff 35s in it without more lift.
That_Hal
Hal
Ford F150 and Volvo S90
Dear friends, it’s time I finalize my build. To Sasquatch or no? I’m in Florida and won’t off-road often. My reason to do it would be looks and resale value. The reason not to do it is I won’t use it, cost, and could delay my order. My build is badlands 4 door.
What would you do?
It's not that much more money to do it and you will see someone in the road with it and you will say to yourself "Shit, I should done Sasquatch". You will probably say it a lot.
bytheway
Brice
Louisville, KY
Super duty 4x4 pickups go from 32/33s standard (275/65/18 AS or 275/70/18 AT) to 35s with the tremor package (285/75/18 AT)
Rebel Bronc
Rob
Central NY
'23 OBX, 2dr, V6, 4.27
I've seen two lifted vehicles where I work sporting 35 x 12.5 tires. In person, they are freakin huge. I'll be just fine with lesser tires.
GatorDave
GatorDave
Tampa
  • Like
Reactions: abe
Gamecock
Have you seen them on a 4 door Wrangler? That gives a good comparison, as the wheelbases are close. They don’t look that big on the Wrangler...they look proportional, while stock 33s (Rubi) look fairly small, or the minimum acceptable at best.
Masterwaterskier
Houlton, WI
'13 Raptor, '79 Bronco, '23 2Dr BD Squatch
Just ordered mine BD with Squatch...
just an FYI.. In case you want to see what the tires look like, the tire size on the squatch is the same stock tire size as the Raptor which helped me decide as I have a '13 Raptor.. I don't want my Bronco to look too small next to my truck.
Sean492
Sean
Canada
70 Ford Mustang Boss 302 and 2011 Ford F150 FX4
I ordered a 4DR Badlands no Squatch. Badlands is pretty much already Squatched with just a smaller lift and smaller wheels and tires.
I'm in the same boat and someone posted in a recent thread while at KOH that the measurement from wheel to fender on a BL and the WT with SAS was identical, so there really is no difference. the 4:46 will do the job and I'll be looking at swapping the hoofs to BFG KO2 285/75/17 as soon as I can. ;)
BD1
BD1
IL
I do this every day in my garage with a 2 door Rubicon on 33 KO2s. I am ordering 2 door Badlands and have decided to stay with 33 KO2s with the optional wheels. And I really like the KO2s. I have had KM2s, NIttos , Duratracks and KO2s are my favorite with Duratracks a close 2nd.
I think the stance and proportions of the 2 door look better with 33s. I have looked at 2 door Jeeps with 35s and prefer 33s. Now the 2 door Bronco is slightly larger than the Jeep but in all the pics/videos I have seen I still prefer the 33s on the 2 door.
If I was getting a 4 door I would probably get the sas. I think the 33's on the 4 door look good but just like 4 door Jeeps the 35s look good (better?) also. I have had 4 door Jeeps and had 35s on them.
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
What would you do?
Personally I think on the 4 Door the 35s look better, but looking at your post objectively, I would suggest you stick with the 33s to begin with.
There will be Squatched owners selling off their Stockers within months of purchase so you will have plenty of options if you decide you really want slightly bigger meats
Rover72
Craig
Northshore MA
23 Badlands - 23 Outer Banks
My guess, I do not think either BL SAS vs Non SAS will matter significantly with resale $$ or desirability. There are buyers for both versions. BL non SAS or SAS will sell equally as well, IMO.
I would buy the look you like for your enjoyment unless money is a consideration in which case buy the lower price version.
