Off-Roadeo Question: Winch demonstrations?
FishKzor
Tom
Phoenix, AZ
2009 Mustang
I feel shame for using a new post to ask this, but my father-in-law brought up a good question when I told him about my Off-Rodeo appointment in September:
Will they be giving demonstrations (do’s and don’ts) for winching? I hadn’t considered this, but maybe there’s an off chance since a winch is an available accessory? (I’ve never had a truck with a winch, and could see one in my future on the Bronco)
Anyway, if anyone has any insight, I’d appreciate it.
Thanks
Tom
Ford Bronco Off-Roadeo Question: Winch demonstrations? A2C75CC8-B720-45FA-BF56-931EA5A1190A
jwoobs
Detroit
They did not do any winching demos in TX.
Closest thing was we stopped to talk about traction mats, but no demo of those either.
Edit: actually I forgot they mentioned the off road recovery accessory kit and how to attach hard and soft shackles for recovery with another vehicle. But nothing specific to winch usage.
JaxGtc
They talked about winching being an important part of off-roading but they noted it was not part of the off-rodeo primarily because none of the vehicles were equipped. They also mentioned that there would be a lot of things to cover in winch operations and time limitations would not do it justice.
USBDLNDS123
Ohio
Car
Thanks
Tom
Tom
we did not do any winching demonstrations but they did talk through it. We also recovered a bronco stuck in the mud courtesy of myself while we were there using recovery boards and recovery straps.
USBDLNDS123
Ohio
Car
They also mentioned doing a specific recovery class in the future but nothing is locked in regarding this.
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
The closet thing was discussing how the capacity of the winch is reduced by how short your cable is. The longer your cable, the closer to full capacity, etc. Advised on using winch pulley to lengthen the amount of cable on a short pull if severely stuck.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Tom
Sounds like you just did that to “help in the demonstration”… Right? ;)
Rivers90
Ben
Southern California
2 Door Base Sasquatch
Winching is a huge subject. I can see them not having time for it.
Never pull or shock load a winch. Use a recovery rope attached to the recovery hooks or hitch if your pulling with another truck.
Have a snatch block and slings to make anchors. Anchors are a big subject too.
Always leave 8 raps of winch rope or cable on the winch drum. Don't pull out all the cable.
Keep your rope cable spooled cleanly. This may mean after use spooling your cable or rope out and neatly rewinding it.
If your using steel cable use gloves. The cable will end up with sharp stands over time. Don't hook the cable to its self use a strap if your raping around something.
