OEM Modular Bumper Bolts Removal?
ofm636x
Omar
Kuwait
2022 Ford Bronco Badlands
Hello, does anyone have an idea on how to get to this bolt without having to remove the grille? I am gonna be installing a bracket for my license plate (similar to the 2nd photo) so I just need to unscrew the bolt a bit to slide the bracket below the screw.
Ford Bronco OEM Modular Bumper Bolts Removal? IMG_6411
Ford Bronco OEM Modular Bumper Bolts Removal? IMG_6413
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
ofm636x
Omar
Kuwait
Update: In case anyone having the same issue, I made myself a low profile screw driver to remove the bolts. I cut 10 mm of a T40 bit and welded it to a thin handle.
Ford Bronco OEM Modular Bumper Bolts Removal? imag
Mr Toad
Ben
Pacific Northwest
2023 Bronco Badlands Sasquatch 2dr
The bumper bolts are Torx Plus 40 (TP40). Regular Torx fit loosely so there's a risk of damaging the fastener. You'll want a real TP40 bit to keep in your Bronco toolkit if you plan on doing any rock crawling so you can remove the ends of the bumper for better approach clearance.
I found a different plate bracket that mounts lower on the modular bumper on bolts that are much easier to access, and it's inexpensive.
https://amzn.to/3SDQCUo
Ford Bronco OEM Modular Bumper Bolts Removal? LicensePlateHolder1
Ford Bronco OEM Modular Bumper Bolts Removal? LicensePlateHolder2
this doesn't work. so don't buy it.
i read that it works on the and it obv doesn't
https://www.amazon.com/dp/B07TC79LVH?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
still can't get a consensus on what to get or use
This kit works on almost all the bolts but, unless you have a winch or something in the way, it’s way easier to just loosen the 6 bolts and drop the bumper down than trying to get at it in such a tight spot
https://www.amazon.com/gp/aw/d/B004UC9WJE?psc=1&ref=ppx_pop_mob_b_asin_title
Smocaine
DFW, TX
Cervelo Caledonia
Mislabelled, as no-name Amazon tools tend to be, but that much should have been obvious from the picture. You can tell Torx Plus by eye - it has six lugs, chunkier than the pointy tips of regular Torx, and no pin-socket in the tip. Amazon search will not help you with this.
I have this kit. European made and available from many retailers.
https://www.wihatools.com/products/torxplus-short-arm-l-key-9pc-set-ip8-ip40
