Odd behavior in HVAC system.
sledboy
2021 Ford Bronco, RZR XP4 Turbo
There is something happening to our HVAC system that doesn't seem normal. While we are cruising down the road at 70ish mph, we will periodically and suddenly get a very high volume of air flowing through our vents. A quick check to the fan speed shows it is still set on 1. But the amount of air flow is equivalent to the fan being on high.
I believe there is "valve" of sorts (not sure what it is called) in the ducting system that opens and closes to allow outside airflow. When the valve is open, the higher the vehicle speed the higher the air flow through the vents. The odd behavior is that this "valve" seems to randomly open and forces a dramatically high amount of airflow through the vents. Playing with the buttons and turning the recirculation button on/off will usually return the system back to normal. Then 5 to 10 minutes later, it happens again.
Is anyone else experiencing this behavior?
acnp2022
CT
ford
I have heard others talking about it and I have experienced it too before. Doesn't happen that often, but on a longer shift it does happen
sledboy
sledboy
The term your looking for is blend door.
Ah, thank you. So my guess is that the blend door randomly opens and allows high air flow through the vents when the vehicle is traveling at highway speeds.
PapaWE
Ohio
89 Chevy K2500, 07 HD Nightrain
If you are in auto cool mode then it could be sensing a higher temp and trying to compenate
WuNgUn
Ontario Canada
2 door Squatched
Blend door is the actuator for hot/cold I believe... Damper door is outside/recirculate 🤷
da_jokker
Jeep Wrangler JKUR
Pay attention as to if it correlates to your throttle. I had a weird issue like that (not a Bronco) and turned out to be a leaky vacuum line that operated the hvac doors. On throttle would lose to much vacuum and the door would open, off throttle there was enough vacuum to overcome the crack in the line.
LAbronco
Pineville, LA
1986 Ford Mustang, Bronco Base 4 Door VB
I’ve been driving a dealer demo for a week. It randomly does this also. It’s a base and doesn’t have a auto feature that I have seen.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
trying to compenate
You mean, we didn’t all buy Bronco’s with Sasquatch package to compensate for something??!
M&M Beer
Marty
Ford Edge-F-150 Supercrew
Isn't there a damper on the grill that might be modulating?
Bob 07064
Bob
Somewhere in time and space
02 4x4 ranger, '17 edge 2022 Bronco
The blend door is to seal off the heater from the ac and vice versa when one or the other is not in use. The air flow thru it is controlled by the blower fan. Maybe that's the issue... Some how it surged?
MileHighCitizen
Al
Denver
Bronco 2D 2.7
This truck is turning out to be a peice of shit. Im starting to feel dumb for staying on board with my order.
WillyB
William
MN
2011 F150 FX4, 2013 Explorer
I have the same issue. No correlation to speed, throttle, temp, or anything. Sometimes barely blows air and sometimes blasts full on Speed 1. For now I am simply keeping a list of things and will have it all checked out when I go in for my first oil change.
Wanted33
Down south in Dixie
Just to throw this usless bit of information out there. My '20 Ranger with the manual system has so many little odd things going on I won't try to list them here. But, just a readers digest version is the little HVAC lights come on when I start the truck that I know I haven't pushed. Sounds like Ford is using the same system in the Bronco.
BTW, I haven't taken it in as I know I'll hear the dreaded words, "They''ll do that". :)
