Odd behavior in HVAC system.
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
I noticed it would randomly disable the recirculate button allowing fresh air to enter increasing the blower velocity. if you then hit recirculate button it would resume previous setting. I only noticed the fresh air vent opening because wildfire smoke was thick outside. Mmmmm…..
redvettx2
Tom
Scottsdale, AZ
05 Maserati Coupe GT,16 Jag F-Type S,65 Cobra 427
What is going on with the recirculation button at the time. VW automatically turns on the recirc if temp is max low or fan speed is high. Moisture would build up in the air box and cause a musty odor even in AZ. Key was keep the recirc off.
jd-ford-hd
Tennessee
‘16 Explorer, ‘13 F150, ‘99 F350, '74 Bronco
Actually the highly sophisticated "voice recognition" feature of Sync 4 can detect the audibles created by flatulence and will initiate the required air circulation to accomplish mitigation.! :)
69 Mach I
Sean
'15 F-150, '87 Mustang
Mine does that exact same thing at highway speeds. My first vehicle with automatic climate control, so wasn't sure if that was normal......I guess it is for the Bronco!
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
I have this happen in dozens of vehicles. I usually attribute it to the automatic climate control.
22OBX
Bryan
Hartford, AL
Reviving this thread from the dead. I just took delivery and the very first thing I noticed when turning on the ac the damper door didn't sound right. Made a loud sound and opening and closing sound like it's searching for the correct point, and in my past that has always pointed to bad damper motors. I threw it on Forscan and sure enough - 10 miles, I have a DTC - NO CEL but for a 1083B - Recirculation Damper Motor. Additional Fault Symptom - Mechanical Failure. Going in this week and I will post back the outcome.
Leo-Bronco
Leonardo
Miami
2022 bronco
Sooo any outcome? Lol
mine does the same at hwy speeds sometimes starts blowing hard for a little while.
Leo-Bronco
Leonardo
Miami
2022 bronco
Anybody has fixed or has dealer said anything?
JeffROK
South Korea
2022 Outer Banks
22OBX
Bryan
Hartford, AL
Sorry, thought I posted back. Has been working fine with no odd behavior since replacing the motor. I haven’t noticed any of the symptoms of it changing on its own. It seems to stay on when I turn it on and goes off when I turn it off. I do think there may be a function or two if selected, that recirculation mode is not designed to work in, so it turns off. Maybe defrost, I can’t remember and would have to test.
Area51BS
Ron
Badlands non SAS 4dr 2.3
It’s an obnoxious Ford feature. If outside temp is in range. The vehicle will allow outside air in. I think it stems from some past lawsuit. My Maverick and Bronco Sprort do it.
22OBX
Bryan
Hartford, AL
Interesting haven’t noticed that.
Area51BS
Ron
In Florida winters around 50 degrees and at dark is only time I see it. Will see this winter. Haven’t seen it since last winter.
Leo-Bronco
Leonardo
Miami
2022 bronco
For me it seems to be more related to my driving speed then temperature. Yesterday it happend again when i hit 85mph+. Temperature outside was around 75f. I had only been driving like 10 mins.
Ksjrb03
Tx
F250
The blend door that allows outside air in opens even when you have it on recirc. This is a Ford feature to allow “fresh” outside air in even if you don’t want it. The door is located in a space that allows it to flow in faster than the fan would do on its own on low settings. That’s why you notice it more when driving faster. Super annoying.
