No need for catch cans?
Tex
Cliff
San Angelo
Small amounts of condensation will be caught in the catch can over time, a few droplets is nothing to worry about.
There's water in the air filling your crankcase, it gets heated up in the engine and then cools/condenses in the baffles just like the oil does, plus there's some in the exhaust gases that do manage to blow by the rings.
Most of the water is boiled into steam and doesn't get a chance to condense in the catch can, it just goes right back to the intake, but occasionally there's enough of a delta for it to happen.
Fordmanbob
Fordmanbob
Bob
KS
2018 F150 4x4 supercrew, 2006 F350 4x4 superc.
I get it. That's the reason u put the catch cans on....to trap what I could before recycling it back thru the intake system.
JPNC
Charlotte
2011 BMW 335i
If a catch can is needed why isnt there one manufactured into the engine? This is all very confusing to me.
Fordmanbob
Fordmanbob
Bob
KS
Fordmanbob
Fordmanbob
Bob
KS
Cost per unit
Luckylat
RI
1999 Expedition, 2013 VW Wagon, 2023 Wildtrak
While the benefits of using a catch are compelling, my issue with using one would be the risk/benefit of it voiding the Ford Motor engine warranty.
I have read:
"A catch can could void your Ford’s powertrain warranty coverage if it is deemed to be the cause of a powertrain failure. That said, any other active warranty coverage will likely remain intact.
A catch can—for those who don’t know—is an aftermarket device that can benefit vehicles with direct-injection engines. Catch cans prevent oil and other contaminants from causing build-up inside your engine’s intake manifold. But while catch cans are perfectly legal, they almost always void your Ford’s powertrain warranty."
Fordmanbob
Fordmanbob
Bob
KS
I have read:
Nope. Asked my dealer and they said it will not void PT warranty
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
It's not "needed" - but it helps.
Think of it like using premium oil in your oil changes. Needed? No. Can it help extend the life of the engine? Possibly.
If you plan on dumping your Bronco after 5 or 6 years - don't worry about it. It's the next guy's problem. If you plan on driving your Bronco until the wheels fall off than, why not? It's a one-time cost of not a whole lot of money and could give you a few more years out of your engine.
Lèòn
Jersey
Who’s thirsty? Brewed over 3k miles
Ford Bronco No need for catch cans? 7798BD7C-D593-4E86-B3CC-BDA1EDBBD655
Ford Bronco No need for catch cans? 81E754FB-916C-4540-B83B-3642ADF49683
Area51BS
Ron
Badlands non SAS 4dr 2.3
I think it’s worth it. Slowly robs power away as valves get built up with that residue. It’s a slow process and my not be noticeable. However when you get the intake walnut blasted, you will notice the power gain. How do I know? Learned it on the internet and common sense makes it believable. I’m ordering one. Ford isn’t really concerned with a slight power loss years after the warranty expires.
Fordmanbob
Fordmanbob
Bob
KS
More piece of mind for me
Fordmanbob
Fordmanbob
Bob
KS
Exactly
