No Dash Display - Went Black
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
So what ended up being the solution for this? What part was replaced?
This has happened to me 3 times now in the past month and all while driving (have had my Badlands since February 2022). It's only the instrument cluster and NOT my Nav/Radio screen (never had the issue there). Ends up resetting itself after the car has been off for more than 10min and only happens randomly.
Good morning! If you send over a private message including your VIN and dealership info, I'd be happy to look into this for you.
Corsair
Jacob
San Francisco
Escape
Just had this issue pop up. You end up finding out anything?
Soups818
Denver
Badlands Sasquatch
Ford reached out to me on here and escalated it to the support team. They said someone would reach out but I have not heard anything yet
Corsair
Jacob
San Francisco
Escape
Thanks. It started working after being off for a couple of hours. Hopefully it doesn’t turn into a recurring issue.
Soups818
Denver
Badlands Sasquatch
So, I'm finally getting this resolved. Dealer just let me know that the whole instrument cluster needs to be replaced. That's all the info I have at the moment. Waiting on the part and hopefully it gets done tomorrow.
So, for everyone having this issue. Make sure it is happening when you take it in as it most likely won't trip any codes. It finally completely stopped working last week for me, so they were able to see it.
Alaska
‘04 ram 2500
My big bend is doing the same thing- was an intermittent problem, but I guess the screen hasn’t been on in a week now. Calling dealer in the am…
Ford Motor Company
Dearborn
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Alaska
‘04 ram 2500
Friday to Tuesday afternoon: my blank gauge screen was diagnosed as needing to be replaced, brought Bronco back Monday and new screen/ module was overnighted (with required pre programmed odometer) from Ford and replaced on Tuesday. So big thanks to Kendall Ford for making magic happen! Thought I would be without my vehicle for weeks. One night only!
In other news, the bronco sport loaner had seat back rubber mats for the 2nd row- wish my Bronco had those!
Bitchwhitch
Shawn
Englewood, CO
www.projectmidge.com
2016 Ford Edge, 2014 Ford F-150
Just happened to me with my 2021 OBX. Drove it cross country this past weekend with no issues, and now - blank! Help!
Ford Bronco No Dash Display - Went Black IMG_6297
TXDOZER
Les
El Paso TX
2022 Bronco Basesquatch & 2020 Escalade
Just had this happen last night. Read the threads this morning and heard it reset as I loosened the negative cable. Tightened it down and all is well. Hope that’s not a harbinger of a progressive issue.
Coastalcop
3rd Coast
Ok this is based on another thread here , but my instrument cluster went blank after a disconnect of the neg terminal while wiring aux switches. Checked all connections. Everything good , still no screen .
searched here and high and low and found a solution I tried, here it is.
1. pull down panel under steering wheel, it’s just clips and hinged at the bottom
2. Look on left side of now exposed area, this is another fuse box ( might be covered by a plastic card listing default door codes, odd because mine doesn’t have the didgital combo on the doors). Take this card out if present to expose fuses.
3. Pull number 13 fuse and examine it ( three prong fuse). Tested with multimeter all good.
4. reinstall fuse 13 if good and button it back up.
5. start truck
this fixed my instrument cluster and all is well, it did throw a check engine code about fuel and I reset with my scanner, though others have stated it reset on its own after a short drive.
I can’t take credit and my google-fu is weak right now so I can’t credit the guy that originally posted.
hope this works for you like it did for me.
bcl0404
Brendan
2017 F350
5. start truck
Thanks so much for this post. This exact same occurrence happened to me. I followed this post and can attest that it worked and fixed my black dash. 👍👍👍
4DRS4MRWHRS
91' Mustang GT, 14' Mustang GT/CS in GHIG
5. start truck
This worked for me thank you for reposting!
