NEW: Two door Power Tank mount
Status
Not open for further replies.
PTTyler
Tyler
Lodi, CA
powertank.com
2022 Badlands Sasquatch
Update: The Two Door Power Tank mount is for sale!
Use code "PTBronco" for 10% savings on the following SKUs:
Mount by itself: https://powertank.com/products/bkt-2205
5 lb Power Tank Bronco 2dr Edition: https://powertank.com/products/5-lb-2-door-bronco-edition-power-tank
10 lb Power Tank Bronco 2dr Edition: https://powertank.com/products/10-lb-2-door-bronco-edition-power-tank
15 lb Power Tank Bronco 2dr Edition: https://powertank.com/products/15-lb-2-door-bronco-edition-power-tank-1
5 lb Power Tank, Fire Extinguisher, MOLLE pouch:
Ford Bronco NEW: Two door Power Tank mount CHA03432_a6d1568a-a53c-4487-9168-4e0f3ae75d81
10 lb Power Tank, Fire Extinguisher, MOLLE pouch:
Ford Bronco NEW: Two door Power Tank mount CHA03416_ad14d479-6d3f-46ad-8a71-a33d5a3d8265
15 lb Power Tank, Fire Extinguisher, MOLLE pouch:
Ford Bronco NEW: Two door Power Tank mount CHA03420_fa9fd19b-5974-47f8-a134-27746076cf92
Ford Bronco NEW: Two door Power Tank mount PT10-5263CANDYBLUE
5 lb Propane tank, MOLLE Pouch, Quick-Release bracket with fire extinguisher removed:
Ford Bronco NEW: Two door Power Tank mount CHA03436
Here is the first Prototype of the 2 door Bronco mount. This will be used to mount a 5 lb or 10 lb Power Tank or propane tank brackets for a 5 lb steel propane tank or a 6 lb aluminum propane tank. A 15 lb Power Tank or other propane tank brackets can be mounted to this plate with the rear seats folded down or removed.
The plate will mount using the factory hard top bolts and longer bolts on the factory tie down points. The only modification needed will be to drill a small hole through the two "lasso" trim pieces. This mount will be driver side only.
Some feature call-outs:
A: notch in the top plate for access to the plugs for the hard top
B: MOLLE/PALS slots to attach bags or other accessories. The round holes are spaced to mount our billet fire extinguisher mount.
C: These are the "lasso" trim pieces that you will have to drill through to insert the longer hardware. There will be a spacer included to make up for the gap underneath this trim piece.
D: This is where the Power Tank will mount. We moved it as far forward as possible.
When installed, this mount will be a very rigid way to mount your Power Tank or propane tank while taking up as little cargo area as possible.
Ford Bronco NEW: Two door Power Tank mount WIP-2dr- Bronco-Plate-2
Thanks to Jim at Wild Horses 4x4 for letting us use his Bronco for development.
What is a Power Tank? Starting in 1997, Power Tank is the original CO2 air system for off-road. With a high-flow, high-pressure Super Flow regulator, Power Tank is the fastest, most reliable, and most powerful portable air system for airing up tires, running air tools, and more off road. A 10 lb Power Tank like in these photos can air up a 37" tire by 15 psi in about 30 seconds and fill 18 tires on a single tank. With no moving parts or wear items, Power Tanks are dead reliable and all come with a limited lifetime warranty. We routinely see Power Tanks over 20 years old so we can confidently say that a Power Tank is the only air system that will outlive the vehicle it's mounted to.
Power Tanks are refilled with CO2 at any number of welding supply, beverage carbonics, home brew, hydroponics, and aquarium businesses.
Our XP400 outputs 400 psi which is much more than any air tool on the market was designed for. To that end, we make our own line of Ventoso Tire Inflator Gauges, blow guns, and other air accessories that can handle this immense pressure. For general air tool use, our regulators can be dialed back to an acceptable input pressure.
thatspecialbeat
Ryan
Meridian ID
Subies
Like it. Only thought is it may need a spacer to run with the top off. Might not be an issue.
Thanks for the 2 door love.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
The top piece will slide in between the body and the hard top. No spacer needed.
Desert_Brush
SoCal
2015 Mini Cooper
How frequently do the tanks need to be externally/internally inspected to get that DOT transportation sticker?
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
Five years from the date of mfg or before the next fill after the five year mark. We guarantee it to pass inspection or we replace it for the lifetime of the bottle.
Joez60421
Illinois
Fleet of Toyota 4runners and Land Cruisers
Awesome to see! Gives me an excuse to buy another tank so I can just leave it in both vehicles at all times.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
FYI: The 10 lb and 15 lb Power Tanks are the same diameter and are interchangeable in most mounts.
The great thing about having two tanks is you always have one ready to go and don't have to scramble to get your main tank filled between trips.
B34R
Georgia
'04 VW R32, '17 Audi S3, '19 Toyota 4Runner
Will you be able to get to the wiper/defrost & washer fluid connections? Looks like you may need to remove the bracket to get to these two connections?
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
We thought of that. There's a cut out on the top plate to be able to access those spots. See spot marked "A" in the lead photo.
B34R
Georgia
That's awesome. Looking forward to ordering the mount along with our second power tank.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
The final prototype is in! Everything works like it should.
Here is our ideal set up. 10 lb Power Tank, Fire Extinguisher bracket, and a small MOLLE water bottle holder for a screwdriver and crescent wrench.
Super sturdy with four anchor points. Full bolt on with only a minor modification to the "lasso hook" trim piece to get a bolt through. Optionally, you can simply remove the trim piece if you don't want to modify it.
Ford Bronco NEW: Two door Power Tank mount 20230413_160536
B34R
Georgia
Wrapped up install today.
Ford Bronco NEW: Two door Power Tank mount IMG_8414
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
Do you mind sharing details on your battery setup? My bracket should be here this week and I’m looking for a setup similar to what I think you may have.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
Very creative! Great use of the open slots. Would you mind if we used your photo on our website?
And thank you for your business!
B34R
Georgia
I'm running American Adventure Lab Bronco Cargo Floor Multi-Mount – Battery and Compressor Bracket. Went with the 4 lithium battery setup to power my fridge and misc usb items as needed. The Dometic fridge is wired to Dometic DC kit which mounts directly to the Power Tank plate mount. Eventually I'll be relocating the DC kit and fridge once I install a partial rear seat delete.
Status
