New sub?
ski4unc
Van
Nc
Can the factory rear amp be used to power a new sub, possibly stinger gate mounted option?
23 badlands not B/O 7 speaker
Xjeepowner
Randy
Montgomery Texas
18 Camaro 16 JKU Rubicon
I've seen at least one guy that powered an 8" kicker with the factory amp.
You'll have to modify the sub enclosure a bit but a 6.75" kicker fits right in with no modification.
ski4unc
Van
Nc
It can be used I'm sure but would be severely underpowered.
Is there a way to use power line from factory amp to instead power a new amp in that same location? Trying to avoid running new independent power line from the battery.
Sandbergo
Jelani & Dave
Orlando
Rogue
I wouldn’t want to use the power for the factory amp but I suppose it would matter what amp you are putting in. Are you trying to avoid cost or something?
Silence
SD
2022 Bronco
Any proper amp will require power direct to battery. If you're not interested in doing that I would recommend the fusion app with the kicker 6.75-in subwoofer.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
@Silence is correct.
The factory amp has a 12-gauge wire I believe... so... that's probably enough to power a 200 watt amp... maybe a 250 watt amp if you feel like pushing it.
If you are doing a tailgate sub, you're looking at a 400+ watt amp (should be much more)... and the only way you are doing that is by running a 8 gauge wire from the battery to the back.
1st 75th ranger
jeffrey
nj
generally not
you need a 5 channel amp 2 for front 2 for back another for sub
also a sound processor will help
and try mti acoustic for tail gate sub slim 10 bigger box or slim 12 smaller box
