NEW PRODUCT | Diode Dynamics HitchMount LED Pod Reverse Kit
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
@4x4TruckLEDs.com Any new info on using this with a 4 pin harness? I had to go aftermarket on my hitch. Really like the strobe on the brake light since my first Bronco got rear ended twice, lol.
You’ll need to use a 7 pin to 4 pin adapter
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
uslfcfan
Danny
Atlanta GA area
2023 Bronco Black Diamond
Similar idea but you need the correct adapter - you don’t have a 7 pin so you need an adapter to convert your 4 pin to 7 pin
Ok which means more wiring I wouid have to do manually then I would think? Do you have Info on how others have done that by chance? Would it be easier for me to go with one of your reverse light kits that can do brakes as well? Do any of those strob? You have kits to hook those up, correct? Thanks!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
None of our kits strobe
the only kit we sell that has brake integrated is our C1R reverse kit: https://www.4x4truckleds.com/2021-f...w-diode-dynamics-lights-kr-off-road-brackets/
