New Illuminated Third Brake Light for Bronco
OracleLights
New Orleans, LA
www.oraclelights.com
Looking to add a functional Bronco third brake light or a stylish spare tire ring? Get the look you want with the ORACLE Lighting LED Illuminated Spare Tire Wheel Ring Third Brake Light!
Using our durable aluminum wheel rings and our industry-leading 2835 LED illumination, we offer this popular mod in red for a high-powered third brake light ring or in ColorSHIFT® for RGB control of the ring. This vibrant illumination behind your spare tire is guaranteed to grab the attention of everyone around -- either with a brilliant red brake light or any color imaginable displayed. The red brake light provides more safety and visibility while the ColorSHIFT® option allows you to match your other color-changing accessories.
With a universal fitment, the brake light ring has a 13-inch diameter and mounts to the spare tire carrier. A great-looking modification with real functionality, your trail partner can spot your Bronco a half-mile ahead! Improve your rear brake light illumination and get a customized look with this Bronco spare tire ring.
Transform the look of your Bronco's rear end, and enjoy an easy install of this brake light ring with the provided hardware. The extended brackets mount to the spare tire carrier. The wiring is easy; simply tap into your existing third brake light wire.
Ford Bronco New Illuminated Third Brake Light for Bronco Bronco_ThirdBrakeLightcopy_1024x1024
Available in RED to tap into your third brake light, or ColorSHIFT which is suggest for show use only.
Reminder to use code FORUM10 for your forum discount at checkout!
Order HERE!
bpurtz
Bryce
Oregon
JKU Rubi, Sierra Denali, Taco TRD Pro, 4Run LTD
Interesting. Just curious if this could be set up with white led lights that could be wired into one of the auxiliary switches?
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Yes, for sure you can connect the RGB version to any 12V source and make white LED light. No additional parts needed if you have AUX switches already.
Can this be used in addition to the original 3rd break light or does the original have to be removed like in the video?
Yes, you can keep both.
What about some illuminated fender vents?
Interesting idea, tell us more!
Aurongel
M.
Austin, TX
2016 Dodge Challenger RT
I’ve always enjoyed seeing Jeep’s with this type of lighting inside the spare tire. I’d also try to find some 3M cable tie downs to secure that wire coming from the LED ring, I’m not sure i liked how loose it seemed between the tailgate and spare.
I haven’t checked the regulations here in Texas but if this allows me to remove the gooseneck third tail light for that teensy bit of extra visibility then I’m all for it.
Seanette
Seanette
Sacramento, CA
2016 Dodge Dart, 2022 Badlands pending
Are we sure this is street-legal in California with all-red lights? If so, I think this is a great idea.
OracleLights
OracleLights
New Orleans, LA
For federal motor vehicle compliance the third brake light must be red in color, so installing this would not be an issue with stated motor vehicle regulations.
grayshadow
Charles
Humble, Texas
NO
iradi8
Craig
Middle of Earth
2021 Bronco Badlands 4DR 2.7L
Looks great! Does the light affect the rearview camera at night?
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Negative, rear cam still works just fine. No visible difference from road testing.
