New Illuminated Third Brake Light for Bronco
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Anybody else notice that it was raining out and that Bronco was topless, COMPLETELY topless..
Now THAT'S a real Bronco owner
BTW I like the video. Nice, clean, simple, easy to follow. Just a really clean video.
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
Looking to add a functional Bronco third brake light or a stylish spare tire ring? Get the look you want with the ORACLE Lighting LED Illuminated Spare Tire Wheel Ring Third Brake Light!
Using our durable aluminum wheel rings and our industry-leading 2835 LED illumination, we offer this popular mod in red for a high-powered third brake light ring or in ColorSHIFT® for RGB control of the ring. This vibrant illumination behind your spare tire is guaranteed to grab the attention of everyone around -- either with a brilliant red brake light or any color imaginable displayed. The red brake light provides more safety and visibility while the ColorSHIFT® option allows you to match your other color-changing accessories.
With a universal fitment, the brake light ring has a 13-inch diameter and mounts to the spare tire carrier. A great-looking modification with real functionality, your trail partner can spot your Bronco a half-mile ahead! Improve your rear brake light illumination and get a customized look with this Bronco spare tire ring.
Transform the look of your Bronco's rear end, and enjoy an easy install of this brake light ring with the provided hardware. The extended brackets mount to the spare tire carrier. The wiring is easy; simply tap into your existing third brake light wire.
Available in RED to tap into your third brake light, or ColorSHIFT which is suggest for show use only.
Reminder to use code FORUM10 for your forum discount at checkout!
Order HERE!
I love it, but I’m planning on getting a spare tire cover to protect it from UV rays, etc.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
You’re better off rotating the spare through so the uv exposure is the same as any other tire
Hey19
JJ
Bethlehem
I tell myself I shouldn't like this, but I do. If I get this, will it be a gateway to under-body lights and 22" wheels? What will my neighbors think? Will my order arrive in discreet packaging?
mbagne
Matt
Placentia, CA
Mach-E GT
Since I am way past high school I don't feel invited to begin making these types of mods. However, I am not being a nay-sayer . . . something inside me says I like it, and it is cool. But then again, why stop there . . .
Ford Bronco New Illuminated Third Brake Light for Bronco Lights 1
Ford Bronco New Illuminated Third Brake Light for Bronco Lights 2
privateer35
Seattle
Ford Bronco 2021
This has potential! I like it!
D190065
Danno
Plant City, FL
21 Bronco FE; 2015 HD RGS; 23 F150 Tremor ordered
Here it is installed on my FE. Easy install and yes the wheel is heavy as hell. I followed the instructions on the video.
@ORACLE Lighting ...only a suggestion, make the connect wires at least six inches longer for those that want to keep the factory third brake light and use existing harness channel. It works as is, but really tight to use your provided hardware. I almost clipped the ends to add a little extra wire. And secondly, and I know these are universal, but I had to bed the ends of the mounting brackets to accommodate the large camera cover. Even though I could have cut them myself, making them an inch shorter would have been perfect. Needless to say, I love the product!
Ford Bronco New Illuminated Third Brake Light for Bronco IMG_E2407_LI
Ford Bronco New Illuminated Third Brake Light for Bronco IMG_2410_LI
WuNgUn
Ontario Canada
2 door Squatched
Yeah, just as I thought...nowhere near as bright as the brake lights. These must use lower power LED's, not Lumiled, OE automotive quality LED's
OracleLights
OracleLights
New Orleans, LA
www.oraclelights.com
Thanks for the feedback; we will definitely pass it along!
Pics look great too; could we add them to the product page to help other owners see it installed?
D190065
Danno
Plant City, FL
Apologies for the delay. Yes, you can use them.
MikeyFrog
Iowa
Why not a compatible plug instead of taps? I hate tapping wires
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Some installers like to keep the existing brake light and others like to eliminate it. If we had a connector it would prevent you from being able to utilize the existing light, add cost to the product, and no longer make it a universal fitment.
@ORACLE Lighting any chance making one that would change into white if we put the vehicle in reverse?
Yes, if you order the RGB version and just ground all 3 ground wires it will only light up white. Just not that this makes a soft glow, it does not project light rearward so its not going to provide much in the way of usable light when reversing.
