New gears for 35" tires?
Glen24
Glen
Illinois
24 bronco
If staying with 35" tires, is there any benifit to changing front and rear gears. If there is what gear would you go with?
Low gear number (higher/taller geared) will get better fuel economy, but lower acceleration and low end torque at the wheel. You can gear tall enough (or rather, select a tire big enough) that your top gears become useless as you don’t have enough torque at the wheel to run them any longer
Higher gear number (shorter/lower geared) will have more torque but will shift more often, you can gear low enough that it’s too short and needs to skip gears.
It’s a tradeoff, like most things. Ford selected 4.70 for their 35ā€ package, but even the 3.73 will run 35s without breaking anything - you just won’t be smoking people off the line with a setup like that. There are kits to go as low as 5.38 if you wanted to.
Valhalla
Valhalla
Chattanooga Tn
If i were never coming off 35's I would shoot for around a 4.10 ~4.30.
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
Ford picked 4.70 for efficiently/fuel mileage with the steep overdrives in the trans and higher rpm ranges of the smaller engines…works pretty good for 35s…I would like 5.38s with my 37s but not enough to change them…what was the question again?…
