Bobby
Upland, CA
12 Toyota Tacoma
Forgive me if this question was asked already but I’m assuming the cat back for a 4door will not fit a 2door correct? That outlaw high clearance cat back is calling my name but I don’t see an option for a 2 door on your site. Thanks in advance for the clarification!
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
We do also have a 2.3L test vehicle. Let me get an answer for you!
Eagerly awaiting that answer. Would also love dyno numbers on outlaw 2.3. Whenever you can post either one you'll probably have my money.
Outlaw product description says "...better departure angle..." - is this due to the muffler being deleted or is the tubing routed tighter somehow (or both)? I presume any factory heat shielding can remain with this?
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Scroll down, under "Tech Resources" pretty sure it's for both, guessing by way of an extra section you don't install for the 2dr
Wish ARBs rock rails worked this way. Or that they just release the gol dang 2dr version already @#$%*&!
Bobby
Upland, CA
12 Toyota Tacoma
Thanks man! I actually noticed that after posting lol. I guess having an unused pipe instead of two different kits makes stocking / packaging easier. Or perhaps Ford managed to have the cats in the same exact spot for all Bronco’s regardless of doors / engines?
RedHotFuzz
2022 Bronco Black Diamond 4D
Waiting for some customer feedback on these. I will really miss my Durango R/T exhaust note and will be looking to improve the factory exhaust on my Bronco (if I ever get it).
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
Hey everyone! We just launched SEVEN NEW exhaust systems for both the 2.3L and 2.7L models here at Holley under the Flowmaster brand name.
FlowFX Axle-Back: This system uses a FlowFX style muffler for a deep exhaust tone and increased performance. Maximum dyno gains of 17 hp and 18 lb-ft. were measured at the rear wheels.
https://holley-social.com/718123FlowFXAxle-Back
FlowFX Cat-Back: This system uses a FlowFX style muffler for a deep exhaust tone and increased performance. Maximum dyno gains of 12 hp and 13 lb-ft were measured at the rear wheels.
https://holley-social.com/718122FlowFXCat-Back
I suppose I could break out the sawall and make one of the FlowFX kits a “high clearance” option, but that seems like a waste. Can you please just make that an option? Even if it’s just single exit?
Also, 2.3 specs as well 🤞🏼
4avor8ntfair
Houston, TX
Actually @Holley Performance Co. , something like one of these that you make for the Gladiator would be perfect. Probably the Outlaw Extreme system for extra clearance. If you have a universal one, I can just swap it out for the muffler 🤷🏻‍♂️
https://www.holley.com/blog/post/fl...st_systems_add_power_and_off-road_capability/
Weasel2021
Sean
South Carolina
Bronco Badlands and Bronco Sport Badlands
@Holley Performance Co. Are there plans for a dual mode w/ active valve exhaust? I'd like to be able to switch between stock noise levels and aggressive. Good use of uplifter switch... Also don't want to be "that" neighbor when I'm warming the Bronco up early in the AM.
antman92
Toronto
Edge
im LOVING the outlaw catback sound. i wonder how many organs i need to sell to ship to canada
EBG
71EB
Impressive. They've taken a modern, dual turbocharged, direct injected V6 in a 4x4 off-road icon and somehow managed to make it sound exactly like a crap ricer Honda from 30 years ago.
Pass.
Deleted member 32220
Guest
This is going to go over well. There won’t be any performance gains on the 2.3. It will be for sound only. The 2.7 could benefit from a reduction in back pressure, due to the convergent flow from 2 cylinder head banks. An increase in flow is just not needed on the 2.3 at stock boost levels. Maybe with ford perf. / livernois tune it would be beneficial.
Inlinejohn
WA
Several
