24GTBadlands
IL
24 Badlands v6 (3 inch lift), 24 S650 with PP GT (pre-production), 1971 Mach1
The subwoofer was set to off on my 2025 OBX with the B&O speakers. Does turning it on actually do anything?
Earlier in the thread, a couple of us asked that. When I got to that section I did not hit the "write" button or make a change there. If you look at that default screen it also says "Center dash tweeter" NONE, but I put my hand over it and it was still working so I left that page.
My Sub is still working even though it showed none, that is why I left that section. I added Sport Mode turned off the double Honk, and put it in my glove box.
In each section you have to select and upload, I only made the change I wanted so far. Mine came with 35's and I felt no need to mess with that section until I change tires sizes.
So unless you hit the "Write to File" or "Upload Changes" How ever it is worded, nothing has changed.
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
Serious question; has anyone saved a self service maintenance log on their Ford App recently?
The Add Service throws a "Please try again later.....app isnt responding."
This is on all my devices for the last few days since.......well just curious if anyone else has noticed. 🤔
chopperbobby
bob
northern ky
2025 bronco
Tried up loading baja on mu 2025 obx lux. It loaded but got a parking brake needs aervice and would not disengauge. Remove baja and back to normal?
Also i have b&o system. Showes front soeakers as b&o. The middle rear and sub show no speaker. Dont know what is going on there?
Did do engine noise off quite ride little more road noise not much though
Tybh88
Tyler
Mine is the same doesn't matter if its wifi or 5g. Acts like its going to work then Says it timed out.
NotMchlRly
Covington, KY
2024 Bronco
Anyone else experience a change in the sound of the proximity sensor beeps after making updates? Not a huge deal but I prefer the original sounds.
BobN - USAF
Robert
Tallahassee
2023 Bronco Big Bend, 1942 Ford GPW (jeep)
Yes, I noticed that and my family complained it. LOL. What updates did you make? I turned off the equalizer (no idea what that does as my 23 was a amp/sub delete (with fake amp and sub installed, replaced with Ford Fusion and an Amazon special speaker)), tried the windows up but it doesn't work. oh, yes and changed to the double press on the panic alarm.
Nick72
Nick
North GA
2021 Bronco Base(Traded), 2025 Bronco Outer Banks
So, I received mine Friday afternoon. From then until last evening I have made numerous attempts to disable fake engine noise, double press for the panic alarm, add goat modes (Baja and rock crawl), and seat belt chime off.
I have uploaded the device update twice and takes multiple attempts to change a parameter without getting some sort of error message on the app, and once a brake failure message on the dash.
So far the only thing that has taken effect is Baja mode (I removed rock crawl) and double press for the panic button. All of the changes I mentioned previously indicated that the settings have been saved to the vehicle after I pressed the upload button.
I cannot tell any difference in sound so I assume fake engine noise did not disable.
I will do the seat belt chime mute the old fashioned way by manually locking and releasing the buckle five times with the ignition in the run position.
This all leaves me with one change that actually took which was the double press. I don't really care about Baja mode.
So as it stands, double press is the only real useful change that works, and I originally fixed that problem with. $1.50 carabiner.
24GTBadlands
IL
I mentioned this earlier, my S650 with no mods would not let me log an oil change in the Ford App so they may not be related.
NotMchlRly
Covington, KY
2024 Bronco
Added Sport mode, disabled panic alarm, disabled fake engine noise, turned off start-up & door open chimes, changed power point timeout to 10 minutes, & maxed out steering wheel temp.
chopperbobby
bob
northern ky
2025 bronco
I added Baja mode and got a parking brake needs service. I removed and it went away?
Nick72
Nick
North GA
N8do
Nate
IN
So it is looking like a Ford wide update glitch. Appreciate the reminder. I just wanted to see if anyone else was seeing it. Kinda hoped it would be cleared up by now. :cautious:
Travis9935
Travis
2024 Bronco sasquatch
Yes, in each sub-menu there is a little info button at the top right corner that will display definitions like these:
Why can't this stuff be available on the Pulsar Xt? I have this, I was the 2024 model mule. I would like more stuff available on that please 😅
Superchips_Mktg
Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
Did everyone get this same paper. Nothing on it says ford. Dont want to plug in something thats only ment for mopar
You got an early unit :)
This doc has been updated to specifically state that Bronco owners may discard the module.
