NEW Eibach PRO-LIFT-KIT HD Coilover Replacement Springs at Lethal Performance
Duston@Lethal
Duston
South Florida
2005 Cadillac CTS
What's Going on Bronco Owners!
Duston from Team Lethal here to Announce an upgrade for the Eibach Stage 2 Coilover kits.
This kit uses heavy duty springs with an additional 500lbs of rear static load capacity, and 200lbs in front. If the added weight of a winch or an overland build have you down, get back up with some new springs.
  • Front springs load rated up to 200lbs of additional weight
  • Rear Springs load rated up to 500lbs of additional weight
  • Manufactured using race winning off-road race spring technology
  • Developed to provide balanced control and off-road capability
  • Finished in Heavy-duty corrosion resistant coating system
  • Made in USA
  • Limited-Lifetime Warranty
Check out the charts Eibach has provided to give you a better idea the estimated ride height increase (over stock) depending on weight and trim level.Grab your PRO-LIFT-KIT HD Coilover Replacement Springs here!
Ford Bronco NEW Eibach PRO-LIFT-KIT HD Coilover Replacement Springs at Lethal Performance eibach hd lift springs coilover
Ford Bronco NEW Eibach PRO-LIFT-KIT HD Coilover Replacement Springs at Lethal Performance height_weight chart eibach rear
Desertmountains
‘22 Bronco 2-Door
@Duston@Lethal, are the non HD springs meant as coil replacements for the OEM shocks? I have seen them alluded to but can’t find a specific model for a ‘22 BD 2D 2.3L automatic (hitachi) that is packing on an extra 2-300 pounds in the front. Thank you.
