NEW! Ditch Light Mounts by Fast Intentions
Fast Intentions Inc.
Fast Intentions
Simi Valley, CA
www.fastintentions.com
2021 Bronco 2.7L
Fast Intentions has released Ditch Light Mounts.
Our mounts can be installed with most off-road lights and allow you to adjust your lights to that "perfect position". They are uniquely keyed for Baja Designs LP4 lights, allowing you to use all 3 mounting bolts.
Bronco Ditch Light Mounts : In-Stock & Ready To Ship
  • CNC Laser Cut from 10ga Steel.
  • CNC formed specifically for 6G Bronco.
  • 3D CAD designed for quality fit and finish.
  • Bolt-on installation using OEM Bronco bolts.
  • Durable 2 stage textured black powder coated finish.
  • Keyed for Baja Designs LP4 lights but will work with many other off-road lights including Rigid, Diode Dynamics, and KC.
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_rigid_ditch_1
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_rigid_ditch_3
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_rigid_ditch_2
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_rigid_ditch_4
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_baja_ditch_2
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_baja_ditch_3
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_baja_ditch_1
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions b6g_diode_ditch_1
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BD_LP6_1
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BD_LP6_5
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions ditch lights 1
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions ditch lights 2
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions ditch lights 3
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions ditch lights 4
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Those look great!
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
Here are a few pictures from a recent install that we just finished here in our shop.
Baja Designs LP4 lights installed on our F.I. Ditch Light Mounts. They really help tuck the lights further out of sight from the drivers seat while also allowing adjustability. We prefer this method rather than bolting the lights directly to the cowl.
BRONCO DITCH LIGHT MOUNTS | Fast Intentions
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BD_LP_4_1
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BD_LP_4_2
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BD_LP_4_3
Felix808
SRV CA
Pretty slick guys. I'll have to stop by & check them out :unsure:
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
For those of you that prefer larger size lights, we've confirmed our ditch light mounts will accommodate Baja Designs LP6. I think they turned out great, and still allow you to run an AM/FM antenna.
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BD_LP6_2
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BD_LP6_4
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
Happy 4th of July B6G members! 🇺🇸
Our sale is live on the website until Sunday.
Use coupon code FREEDOM13 to save big on Bronco / Bronco Raptor products.
Fast Intentions - Ford Bronco Products
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions RWB_2
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
Ordered! Thank you. Looking forward to mounting up my LP6s.
Thank you for your business.
LP6 are large lights, but they sure do look good!
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions IMG_2266
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions IMG_2259
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions IMG_2379
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions IMG_2384
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
Black Friday is all weekend longs. If you've been eyeing our products, now is the time to buy.
Use coupon code BF2024 at checkout for discounts to apply. All of our Bronco parts including, exhaust systems, light mounts, and door sill guards will be discounted.
www.FastIntentions.com
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions BF IG
DocPewPro
Jon
Reno
Ford F-250 tremor
I recently upgraded to a set of LP4s for my A Pillers. I used Fast intentions light brackets which worked out great. I also run my off road radio antenna off a mountains 2 metal antenna bracket. With the LP4s the antenna was right in front of the lights causing a glare and light beam interference. I fabricated a new antenna mount that places the antenna off to the side in between the light and driver mirror. This fixed all the antenna issues. If anyone is planning on running this setup or already has this issue I’ve included pictures of my antenna bracket as well as a picture of the previous bracket that blocked the light.
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions IMG_5958
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions IMG_5960
Ford Bronco NEW! Ditch Light Mounts by Fast Intentions IMG_5908
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
