NEW- Capable Bumper M&R 40" PRO series lightbar
MandRautomotive
Mikhail
CA
Fits 2021 2022 2023 2024 2025 Ford Bronco with capable bumper ONLY
  • Curved LED light bar PRO
  • Light bar is made out of 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant. With a rating of IP68, the light bar is dust-tight and water-proof.
  • Perfectly follows the Ford Bronco Standard bumper curvature
  • Stays slim to the bumper for a sleek, built in look
  • Quick and simple install
  • Don't need to remove grille or bumper
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
DUAL COLOR
Main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
  • Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic.
Get more information on the Ford Bronco Capable Bumper 40" PRO lightbar
Installation video and light output videos are soon to follow
Ford Bronco NEW- Capable Bumper M&R 40" PRO series lightbar IMG_5984
Ford Bronco NEW- Capable Bumper M&R 40" PRO series lightbar IMG_9607
MR6996
Marcus Rachard
Fort Smith, Arkansas
2014 Dodge Durango, 2019 Chrysler Pacifica Limited
DUAL COLOR
Looks easy enough, however I do wish there was also an option for 2 or 4 to be ran as fog/driving lights
Arrmjr
Rick
SW Washington
Honda Accord and Civic
DUAL COLOR
Do you have smaller sets available in 6-12 inch sizes? My state requires a front plate and I actually don’t mind the factory one so looking for something to flank it.
MandRautomotive
MandRautomotive
Mikhail
CA
We do have our 11 inch light bars for the Toyota 4Runner but you would have to drill holes in your bumper. I would suggest getting our Capable Bumper Dual Function Fog Light Kit since your state requires a front plate. You can also use coupon code COLBY10 at checkout to get 10% off of your purchase.
2021+ Ford Bronco Capable Bumper Dual Function Fog Light Kit
MandRautomotive
MandRautomotive
Mikhail
CA
Hey guys light up your weekends with our badass lightbar kits! You can use coupon code COLBY10 at checkout to get 10% off of your purchase.
2021+ Ford Bronco Light Bar Kits
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
Looks good!
