M&R Pro Series Curved Lightbars
MandRautomotive
Mikhail
CA
M&R brings you a brand new product. The curved PRO series lightbars. Check out how the look on the Bronco. The kit comes with everything you need to connect them to the AUX switches. Please check out the website for more information at www.MandRonline.com
Ford Bronco M&R Pro Series Curved Lightbars IMG_4724
Ford Bronco M&R Pro Series Curved Lightbars IMG_4718
  • Fits 2021 2022 2023 2024 Ford Bronco/Raptor with modular bumper
  • Dual Color: main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Up to 24,024 lumens. Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
  • Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic. Matches the accent lights on the Ford Bronco. Amber DRL is the perfect match to drive around town
  • Metal bracket is powder coated black
  • Easy install right on top of the bumper or windshield depending on the kit purchased.
  • Uses TIR (Total Internal Reflection) lens is different from our the regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant.
  • Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
  • Combo Pattern: combined spot and driving optics offers a balance between the distance and width
MandRautomotive
MandRautomotive
Mikhail
CA
MandRautomotive
MandRautomotive
Mikhail
CA
MandRautomotive
MandRautomotive
Mikhail
CA
