New Bronco 2023 - no subwoofer.
cmtaz
AZ
2023 Bronco
I got my 23 wildtrack today. I noticed there is no sound coming from the subwoofer grill, so I am assuming that means I have the sub delete. That begs the question when beginning the audio upgrade what if any changes to forscan would be necessary. You'd think that with no sub they would turn the eq off. What have the sub delete folks found?
Thank you
Karl_in_Chicago
Karl
Chicago
Thank you
You seem to be aware of the sub delete so if you search for the big thread on that all of the Forscan changes to support un-deleting the sub are noted in there (as well as in the dedicated Forscan threads).
CalvinT
Calvin
Phoenix, AZ
Look for someone who's replacing their factory subwoofer. That's what I did. The wiring is there, so are a dummy amp and speaker. So you just need to swap them out and make the Forscan change. No need to remove the subwoofer enclosure. You'll need to seal the replacement speaker to the enclosure. I'm still researching what would work best.
